and this:So after I extract the the zip file I place it in the SFC Ex... Am I correct?
This is what I got:
Still not found, so the file architecture is probably still not right.
Can you confirm that when you go on your C: drive, you have a folder called ReplacementFiles, and when you go in that folder, you have 3 folders as well, all started with amd64?
Alright, click on the ReplacementsFiles in the address bar, does it changes to C:\ReplacementFiles?
This is the .zip file I made you download which contain the files needed for the replacements. When you right-click on the .zip file and select Extract All, you should get something like in the screenshot below. Change the extraction path to C:\ReplacementFiles.
Awesome! Now please follow the instructions for the FRST fix again (no need to extract the .zip archive, since you already did it).
https://www.sysnative.com/forums/wi...estore-not-working-post161182.html#post161182
Fix result of Farbar Recovery Scan Tool (x64) Version: 09-07-2016
Ran by melen (2016-07-10 09:39:57) Run:3
Running from C:\Users\melen\Desktop
Loaded Profiles: melen (Available Profiles: melen)
Boot Mode: Normal
fixlist content:
CloseProcesses:
CreateRestorePoint:
Replace: C:\ReplacementFiles\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\desktop.ini C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\desktop.ini
Replace: C:\ReplacementFiles\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3 C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3
Replace: "C:\ReplacementFiles\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Maid with the Flaxen Hair.mp3" "C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Maid with the Flaxen Hair.mp3"
Replace: "C:\ReplacementFiles\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Sleep Away.mp3" "C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Sleep Away.mp3"
Replace: C:\ReplacementFiles\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\desktop.ini C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\desktop.ini
Replace: C:\ReplacementFiles\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv
Replace: C:\ReplacementFiles\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480_5sec_6mbps_h264.mp4 C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480_5sec_6mbps_h264.mp4
Replace: C:\ReplacementFiles\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480i_5sec_6mbps_new.mpg C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480i_5sec_6mbps_new.mpg
Replace: C:\ReplacementFiles\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480p_5sec_6mbps_new.mpg C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480p_5sec_6mbps_new.mpg
Replace: C:\ReplacementFiles\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_10mbps_h264.mp4 C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_10mbps_h264.mp4
Replace: C:\ReplacementFiles\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_MPEG2_HD_15mbps.mpg C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_MPEG2_HD_15mbps.mpg
Replace: C:\ReplacementFiles\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_VC1_15mbps.wmv C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_VC1_15mbps.wmv
Replace: C:\ReplacementFiles\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsat.wmv C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsat.wmv
Replace: C:\ReplacementFiles\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsatencode.wmv C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsatencode.wmv
"C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\desktop.ini" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\desktop.ini
"C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3
"Replace: "C:\ReplacementFiles\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Maid with the Flaxen Hair.mp3" "C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Maid with the Flaxen Hair.mp3" -> not found => Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3
"Replace: "C:\ReplacementFiles\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Sleep Away.mp3" "C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Sleep Away.mp3" -> not found => Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3
"C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\desktop.ini" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\desktop.ini
"C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv
"C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480_5sec_6mbps_h264.mp4" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480_5sec_6mbps_h264.mp4
"C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480i_5sec_6mbps_new.mpg" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480i_5sec_6mbps_new.mpg
"C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480p_5sec_6mbps_new.mpg" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480p_5sec_6mbps_new.mpg
"C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_10mbps_h264.mp4" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_10mbps_h264.mp4
"C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_MPEG2_HD_15mbps.mpg" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_MPEG2_HD_15mbps.mpg
"C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_VC1_15mbps.wmv" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_VC1_15mbps.wmv
"C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsat.wmv" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsat.wmv
"C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsatencode.wmv" => not found
Could not replace C:\Windows\WinSxS\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsatencode.wmv
The system needed a reboot.
==== End of Fixlog 09:40:19 ====
I see that these files are "music & videos samples" ... Do I really need these files??? And if so, why are they important???
The new FixFile text by FRST states "that the they could not be replaced or not found". I'm wondering what is going wrong. The fix seems so simple just to replace the files...... I must be doing something wrong....... What do you think???
Follow the instructions in this post again please.
https://www.sysnative.com/forums/wi...estore-not-working-post161225.html#post161225
And I think what's happening is that the file architecture is still not correct. We'll see what the dir command returns.
Alright so the file architecture for the FileReplacements folder is good. Now, go in your C:\Windows\WinSxS folder. There will be tons of folders. Can you validate that these three exists?
Code:amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4
