So you can't boot the machine now?
DISKPART> list partition
Partition ### Type Size Offset
Partition 1 Primary 1861 GB 1024 KB
Partition 2 System 100 MB 1861 GB
Partition 3 Recovery 990 MB 1862 GB
DISKPART> list volume
Volume ### Ltr Label Fs Type Size Status Info
Volume 0 C x64 NTFS Partition 1861 GB Healthy Boot
Volume 1 FAT32 Partition 100 MB Healthy System
The Windows Memory Diagnostic tested the computer's memory and detected no errors
Run a memory check
Code:The Windows Memory Diagnostic tested the computer's memory and detected no errors
Any other ideas what to do ? Windows have problems with fixboot even when the drive is only one connected, so I don't think changing cables will do anything.
It seems like the system shutdown or restarted in the middle of applying the wim file!
dism /Apply-Image /ImageFile:D:\Sources\install.wim /index:6 /ApplyDir:C:\IMGTEST\
Applying WIM file: C:\$WINDOWS.~BT\Sources\Install.wim, index 6(create EAs), to C:\$WINDOWS.~BT\NewOS. Work dir: C:\$WINDOWS.~BT\Work
Well, for start - it is a different execution environment (Safe OS vs Full OS). Second - are you sure that this step is also executed by DISM and not by some other mechanism ?
