You have some odd errors in the System log -
The Process creation detector. service failed to start due to the following error: The system cannot find the file specified.
The following boot-start or system-start driver(s) failed to load: ElbyCDIO, nbraw
The risdptsk service failed to start due to the following error: The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
The HP Software Framework Service service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
The Microsoft Software Shadow Copy Provider service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
The shadow copies of volume C: were aborted because the shadow copy storage could not grow due to a user imposed limit.
Configuring the Page file for crash dump failed. Make sure there is a page file on the boot partition and that is large enough to contain all physical memory.
The Application logs also show some interesting errors (most from the above problems)...
IExplore crashed referencing d3d11.dll
ALso, I suspect that this one is the one that you are seeing when you attempt to install your drivers?
Product: Intel(R) Network Connections -- Cannot install drivers. No Intel(R) Adapters are present in this computer.
I see references to both AVG and MSE in there - which if this is the case, will certainly cause problems. you need to decide on one only, and uninstall the other ( would suggest keeping MSE, at least for the moment - and running the AVG 2013 remover tool from
http://www.avg.com/gb-en/utilities )
The first error in the list is concerning - it may well be residuals from a cured rootkit (My skills in this area are limited - so I'm going to ask for assistance here)
The ElbyCDIO is from Elby Virtual CD - you should probably uninstall (and reinstall?) that.
The nbraw error - I can't find much/any information on, so we'll have to see if we can find something on your machine. (more later)
The CheckSUR result is disappointing -
Checking Component Watchlist
(f) CBS Watchlist Component Missing 0x80070002 x86_microsoft-windows-w..ellibrary.resources_31bf3856ad364e35_0.0.0.0_en-us_41606b1d436caeb5 Package_28_for_KB970158~31bf3856ad364e35~x86~~6.0.1.9 Package registry presence failed, possibly an orphaned package on package watchlist
(f) CBS Watchlist Component Missing 0x80070002 x86_microsoft-windows-w..ellibrary.resources_31bf3856ad364e35_0.0.0.0_en-us_41606b1d436caeb5 Package_103_for_KB970158~31bf3856ad364e35~x86~~6.0.1.9 Package registry presence failed, possibly an orphaned package on package watchlist
(f) CBS Watchlist Component Missing 0x80070002 x86_microsoft-windows-wdf-kernellibrary_31bf3856ad364e35_0.0.0.0_none_9a2d0de766165520 Package_26_for_KB970158~31bf3856ad364e35~x86~~6.0.1.9 Package registry presence failed, possibly an orphaned package on package watchlist
(f) CBS Watchlist Component Missing 0x80070002 x86_microsoft-windows-wdf-kernellibrary_31bf3856ad364e35_0.0.0.0_none_9a2d0de766165520 Package_101_for_KB970158~31bf3856ad364e35~x86~~6.0.1.9 Package registry presence failed, possibly an orphaned package on package watchlist
I had hoped from the SFCFIx scan results, that it had fixed these errors
- but it seems likely that there are deeper problems than normal, so I'll have to pass the buck back again.
Meanwhile, back to 'nbraw'
Please open an Elevated Command Prompt, and run the following commands
REG QUERY HKLM\SYSTEM\CurrentControlSet\Services\nbraw
REG QUERY HKLM\System\Enum\Root\LEGACY_nbraw
REG QUERY HKLM\System\Enum\Root\nbraw
Post the results.
Also, in Device Manager click on the View option in the toolbar, and select View hidden devices
with luck there will be an entry there for 'nbraw' - probably with an error flag on it - please copy the details to your reply, so we can try and find out what it is.
