Vista Hardware Driver Removal
OK (nothing in the Non Plug an Play area?)
Please Uninstall that driver, - if it asks you if you want to remove the drivers completely, say yes.
Then reboot.
Wait for Windows to reinstall any required drivers, and note what they are, if necessary - then reboot again
open Device manager, and see what's now installed there - post a screenshoot of the same area.
Vista auto tries to insatll the Lan Adapter driver on boot up. Vista will ask for the install cd which I do not have so I point the insatll to the downloaded driver file for this device but it can not install the3 driver.
Some extra info for you, the registry keys that are installed by vista at startup for the Lan Adapterd do not have all the values in them at this key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_1000&SUBSYS_30BB0004&REV_00\4&2ca88c27&3&00E2
Key Name: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_1000&SUBSYS_30BB0004&REV_00\4&2ca88c27&3&00E2
Class Name: <NO CLASS>
Last Write Time: 3/31/2014 - 2:06 PM
Value 0
Type: REG_DWORD
Data: 0
Value 1
Type: REG_MULTI_SZ
Data: PCI\VEN_8086&DEV_1000&SUBSYS_30BB0004&REV_00
PCI\VEN_8086&DEV_1000&CC_020000
Value 2
Type: REG_MULTI_SZ
Data: PCI\VEN_8086&DEV_1000&REV_00
PCI\VEN_8086&CC_020000
PCI\VEN_8086
PCI\CC_020000
PCI\CC_0200
Value 3
Type: REG_DWORD
Data: 0x10040
Value 4
Type: REG_SZ
Data: @system32\drivers\pci.sys,#65536;PCI bus %1, device %2, function %3;(5,0,0)
Key Name: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_1000&SUBSYS_30BB0004&REV_00\4&2ca88c27&3&00E2\Device Parameters
Key Name: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_1000&SUBSYS_30BB0004&REV_00\4&2ca88c27&3&00E2\LogConf
Value 0
Type: REG_RESOURCE_REQUIREMENTS_LIST
Data:
Interface Type: PCI
Bus Number: 5
Slot Number: 0
List 0
Descriptor 0
Resource: Memory
Option: 0x00000001
Disposition: Device Exclusive
Type: Read / Write
Length: 20000
Alignment: 1
Minimum Address: 0x00000001
Maximum Address: 0xda000000
Descriptor 1
Resource: Memory
Option: 0x00000008
Type: Read / Write
Length: 20000
Alignment: 20000
Minimum Address: 0x00020000
Maximum Address: 0x00000000
Descriptor 2
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x20
Alignment: 0x1
Minimum Address: 0x00004000
Maximum Address: 0x0000401f
Descriptor 3
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x20
Alignment: 0x20
Minimum Address: 0x00000000
Maximum Address: 0xffffffff
Descriptor 4
Resource: Interrupt
Option: 0x00000000
Disposition: Shared
Type: Level Sensitive
Minimum Vector: 0
Maximum Vector: 0xffffffff
Value 1
Type: REG_RESOURCE_LIST
Data:
Full Resource Descriptor 0
Interface Type: PCI
Bus Number: 5
Version: 1
Revision: 1
Partial Descriptor 0
Resource: Memory
Start: 0xda000000
Length: 20000
Type: Read / Write
Partial Descriptor 1
Resource: Port
Start: 0x00004000
Length: 0x20
Type: Port
Partial Descriptor 2
Resource: Interrupt
Disposition: Shared
Vector: 3
Level: 3
Affinity: 0xffffffff
Key Name: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_1000&SUBSYS_30BB0004&REV_00\4&2ca88c27&3&00E2\Control
I'm by no means familiar with this area of the registry - I have no idea how to approach it!
I'll do some research and come back.
