[SOLVED] [W7SP1 x64] CheckSur.log 0x80070002 - Major WU update issue after system restore.
Does this mean that one of the updates has successfully installed?
SFC Scan
Binary Version 6.1.7601.23471
2017-11-18 15:22
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 198
 No errors detected
Remove Update Manually
wusa /uninstall /KB:2647753
Oops, thanks!
I meant this:
wusa /uninstall /KB:2852386
Can start, but can't finish uninstall with: Access Denied 0x80070005
Runned as administrator.
I am afraid to enter one more time clean boot mode, and see Blank Window 'Turn Windows Features on or off' and 'Installed Updates' one more time......
Step#1 - FRST Fix
Afterwards, try updating and attach CBS.log if it fails.
Is this typical situation, you have to make many procedurs to fix particular KB issue/-s?
Fixlog.txt
Rezultat naprawy Farbar Recovery Scan Tool (x64) Wersja: 18-11-2017
Uruchomiony przez slawo (18-11-2017 16:58:44) Run:7
Uruchomiony z C:\Users\slawo\Desktop
Załadowane profile: slawo (Dostępne profile: slawo)
Tryb startu: Normal
fixlist - zawartość:
CreateRestorePoint:
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-s..e-cleanup.resources_31bf3856ad364e35_0.0.0.0_pl-pl_1405c4ae2e7f6341|Package_18_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.2852386-35_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-s..e-cleanup.resources_31bf3856ad364e35_0.0.0.0_pl-pl_1405c4ae2e7f6341|Package_18_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.2852386-36_neutral_GDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scavenge-cleanup_31bf3856ad364e35_0.0.0.0_none_d8251e2ab2dae075|Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.2852386-1_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scavenge-cleanup_31bf3856ad364e35_0.0.0.0_none_d8251e2ab2dae075|Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.2852386-2_neutral_GDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0|Package_18_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ar-SA~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~bg-BG~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~da-DK~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~de-DE~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~el-GR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~en-US~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~es-ES~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~et-EE~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~fi-FI~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~fr-FR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~he-IL~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~hr-HR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~hu-HU~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~it-IT~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ja-JP~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ko-KR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~lt-LT~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~lv-LV~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~nb-NO~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~nl-NL~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~pl-PL~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~pt-BR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~pt-PT~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ro-RO~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ru-RU~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~sk-SK~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~sl-SI~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~sv-SE~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~th-TH~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~tr-TR~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~uk-UA~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~zh-CN~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~zh-HK~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~zh-TW~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_18_for_KB2852386~31bf3856ad364e35~amd64~~0.0.0.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~0.0.0.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~0.0.0.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB2852386~31bf3856ad364e35~amd64~~0.0.0.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_18_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3]
Punkt przywracania został pomyślnie utworzony.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-s..e-cleanup.resources_31bf3856ad364e35_0.0.0.0_pl-pl_1405c4ae2e7f6341\\Package_18_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.2852386-35_neutral_LDR => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-s..e-cleanup.resources_31bf3856ad364e35_0.0.0.0_pl-pl_1405c4ae2e7f6341\\Package_18_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.2852386-36_neutral_GDR => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scavenge-cleanup_31bf3856ad364e35_0.0.0.0_none_d8251e2ab2dae075\\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.2852386-1_neutral_LDR => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scavenge-cleanup_31bf3856ad364e35_0.0.0.0_none_d8251e2ab2dae075\\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.2852386-2_neutral_GDR => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0\\Package_18_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ar-SA~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~bg-BG~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~da-DK~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~de-DE~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~el-GR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~en-US~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~es-ES~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~et-EE~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~fi-FI~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~fr-FR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~he-IL~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~hr-HR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~hu-HU~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~it-IT~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ja-JP~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ko-KR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~lt-LT~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~lv-LV~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~nb-NO~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~nl-NL~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~pl-PL~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~pt-BR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~pt-PT~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ro-RO~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~ru-RU~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~sk-SK~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~sl-SI~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~sv-SE~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~th-TH~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~tr-TR~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~uk-UA~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~zh-CN~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~zh-HK~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~zh-TW~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Shell-Accessories~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => Wartość pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_18_for_KB2852386~31bf3856ad364e35~amd64~~0.0.0.0 => klucz pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_18_for_KB2852386~31bf3856ad364e35~amd64~~0.0.0.0 => klucz nie znaleziono.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~0.0.0.0 => klucz pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~0.0.0.0 => klucz nie znaleziono.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~0.0.0.0 => klucz pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~0.0.0.0 => klucz nie znaleziono.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB2852386~31bf3856ad364e35~amd64~~0.0.0.0 => klucz pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB2852386~31bf3856ad364e35~amd64~~0.0.0.0 => klucz nie znaleziono.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_18_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3 => klucz pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_18_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3 => klucz nie znaleziono.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3 => klucz pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3 => klucz nie znaleziono.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => klucz pomyślnie usunięto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3 => klucz nie znaleziono.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3 => klucz pomyślnie usunięto
==== Koniec  Fixlog 16:59:09 ====
CBS.log
Download CBS.zip from Sendspace.com - send big files the easy way
Step#1 - FRST Fix
