Hi
2017-05 cumulative update has been failing consistently on my machine with the following error:
2017-05 Cumulative Update for Windows 10 Version 1607 for x64-based Systems (KB4019472)
Some update files are missing or have problems. We'll try to download the update again later.
Error code: (0x80073712)
It goes up to 9% completion, stays there for considerable time, then moves to 10% and within a short time (few seconds) gives error.
I tried running SFC /scannow command, which results in:
Windows Resource Protection could not start the repair service.
I then executed the DISM command:
dism /online /Cleanup-Image /checkHealth
which gave the message that component store is repairable.
I subsequently executed the dism with /restoreHealth option, which completed with 'restore operation completed successfully' message. Subsequent dism execution with /checkHealth option said 'No component store corruption detected'.
The update still fails after 9% to 10% completion.
I downloaded and executed the SFCFix, the output is attached here. I will shortly upload the CBS logs.
Please help.
Thanks
Subodh
Please help.
Thanks
Subodh
