[SOLVED] [Win10v1607b14393 x64] 2017-05 Cumulative upd. fails; no problems detected by SFCFIX.
Try the following again please.
SFC Scan
SFc /scannow failed again:
Windows Resource Protection could not start the repair service.
C:\WINDOWS\system32>copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt"
1 file(s) copied.
cbs.zip is below:
View attachment cbs.zip
Have you tried upgrading your machine to the most current version of Windows 10 by following the steps below? If not, can you give it a try?
1. Download the Media Creation Tool and save this to your desktop. Go ahead and run this as well. Note: Click the Download tool now button when you get to this link.
2. Accept the License Agreement
3. Keep the default Upgrade this PC option and click Next.
4. Let this process complete the upgrade to the newest build and let me know when complete.
I had tried upgrading to Creater's edition and that failed with a message that the component store was corrupted. I will certainly give it a shot again and report.
It probably will be tomorrow.
It has started downloading Windows 10. The progress is up to 62% and going ...
I have a question, does the sfc /scannow need any services to be started (or to ensure that they are running)? I vaguely remember reading it in some thread.
It downloaded Windows 10 and created Win 10 media. Checked for and downloaded updates. Started to Install - 34% complete and then it failed:
The cbs.zip is below:
View attachment CBS.zip
OK, I have some ideas. Can you check for the presence of any of the following logs and if they are available, zip and attach them?
C:\$Windows.~BT\Sources\panther\setupact.log
C:\$Windows.~BT\Sources\panther\miglog.xml
C:\Windows\setupapi.log
C:\Windows\Logs\MoSetup\BlueBox.log
C:\$Windows.~BT\Sources\Rollback\setupact.log
C:\$Windows.~BT\Sources\Rollback\setupact.err
Note: Some of the directories are hidden so you may need to copy and paste the path (i.e. C:\$Windows.~BT\) into explorer to get to the folder. If you are uncomfortable or unable to do this let me know and I can automate the collection of the logs.
C:\$Windows.~BT\Sources\panther\setupact.log - copied and attached in the zip
C:\$Windows.~BT\Sources\panther\miglog.xml - not present
C:\Windows\setupapi.log - not present
C:\Windows\Logs\MoSetup\BlueBox.log - copied and attached in the zip
C:\$Windows.~BT\Sources\Rollback\setupact.log - not present
C:\$Windows.~BT\Sources\Rollback\setupact.err - not present
Rollback folder has only 2 files:
checkpoint.info
reollbackinfo.ini
Zip file below:
View attachment SetupactAndBlueBox.zip
Let me know if the following completes successfully.
Step#1 - DISM /Get Drivers
    DISM /Online /Get-Drivers
  3. If it is successful then when it is done it will show the following in the command-prompt window.
The command failed:
C:\WINDOWS\system32>DISM /Online /Get-Drivers
Version: 10.0.14393.0
Error: 1812
An initialization error occurred.
The DISM log is below:
View attachment dism.zip
FRST Fix
Executed the command as explained:
Fix result of Farbar Recovery Scan Tool (x64) Version: 18-07-2017
Ran by subodhan (20-07-2017 22:21:45) Run:1
Running from C:\Users\subodhan\Desktop
Loaded Profiles: subodhan (Available Profiles: subodhan & .NET v4.5 & DefaultAppPool & .NET v4.5 Classic)
Boot Mode: Normal
fixlist content:
C:\Windows\servicing\version\10.0.14393.82
C:\Windows\servicing\version\10.0.14393.82 => moved successfully
==== End of Fixlog 22:21:45 ====
The command failed again:
Error: 3
DISM log is below:
OK, I think I have a handle on what we need to do.
2017-07-21 08:00:51, Error                 DISM   DISM OS Provider: PID=24332 TID=21576 "Unable to retrieve servicing stack folder for DLL search path modification." - CDISMOSServiceManager::SetDllSearchPath(hr:0x80070003)
Please do the following. Zip up and attach or provide a link to the following two files.
C:\frst\Hives\SOFTWARE
C:\frst\Hives\COMPONENTS
If you don't see the COMPONENTS file in this location you can simply grab a copy from C:\windows\system32\config
Remove Update Manually
wusa /uninstall /KB:3194496
3. Let me know if it says it was successful or if there are any errors.
This is what was displayed:
cbs.log:
2017-07-21 21:24:36, Info CBS TI: --- Initializing Trusted Installer ---
2017-07-21 21:24:36, Info CBS TI: Last boot time: 2017-07-19 22:13:10.484
2017-07-21 21:24:36, Info CBS Starting TrustedInstaller initialization.
2017-07-21 21:24:36, Info CBS Ending TrustedInstaller initialization.
2017-07-21 21:24:36, Info CBS Starting the TrustedInstaller main loop.
2017-07-21 21:24:36, Info CBS TrustedInstaller service starts successfully.
2017-07-21 21:24:36, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2017-07-21 21:24:36, Info CBS Startup processing thread terminated normally
2017-07-21 21:24:36, Info CBS TI: Startup Processing completes, release startup processing lock.
2017-07-21 21:24:36, Info CBS Starting TiWorker initialization.
2017-07-21 21:24:36, Info CBS Ending TiWorker initialization.
2017-07-21 21:24:36, Info CBS Starting the TiWorker main loop.
2017-07-21 21:24:36, Info CBS TiWorker starts successfully.
2017-07-21 21:24:36, Info CBS Universal Time is: 2017-07-22 01:24:36.925
2017-07-21 21:24:36, Info CBS Loaded Servicing Stack v10.0.14393.0 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\cbscore.dll
2017-07-21 21:24:36, Info CBS Failed to load WCP DLL: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\wcp.dll [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:24:36, Info CBS Failed to load WCP DLL. [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:24:36, Info CBS Failed to initialize the Core DLL: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\\cbscore.dll [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:24:36, Info CBS Failed to initialize CBS class factory. [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:24:36, Info CBS Failed to create a worker session [HRESULT = 0x800700c1]
2017-07-21 21:24:36, Info CBS Failed to create worker session. [HRESULT = 0x800700c1]
2017-07-21 21:24:36, Info CBS Failed to get worker session. [HRESULT = 0x800700c1]
2017-07-21 21:26:37, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2017-07-21 21:26:37, Info CBS TiWorker signaled for shutdown, going to exit.
2017-07-21 21:26:38, Info CBS Ending the TrustedInstaller main loop.
2017-07-21 21:26:38, Info CBS Starting TrustedInstaller finalization.
2017-07-21 21:26:38, Info CBS Ending TrustedInstaller finalization.
2017-07-21 21:28:52, Info CBS TI: --- Initializing Trusted Installer ---
2017-07-21 21:28:52, Info CBS TI: Last boot time: 2017-07-19 22:13:10.484
2017-07-21 21:28:52, Info CBS Starting TrustedInstaller initialization.
2017-07-21 21:28:52, Info CBS Ending TrustedInstaller initialization.
2017-07-21 21:28:52, Info CBS Starting the TrustedInstaller main loop.
2017-07-21 21:28:52, Info CBS TrustedInstaller service starts successfully.
2017-07-21 21:28:52, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2017-07-21 21:28:52, Info CBS Startup processing thread terminated normally
2017-07-21 21:28:52, Info CBS TI: Startup Processing completes, release startup processing lock.
2017-07-21 21:28:52, Info CBS Starting TiWorker initialization.
2017-07-21 21:28:52, Info CBS Ending TiWorker initialization.
2017-07-21 21:28:52, Info CBS Starting the TiWorker main loop.
2017-07-21 21:28:52, Info CBS TiWorker starts successfully.
2017-07-21 21:28:52, Info CBS Universal Time is: 2017-07-22 01:28:52.840
2017-07-21 21:28:52, Info CBS Loaded Servicing Stack v10.0.14393.0 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\cbscore.dll
2017-07-21 21:28:52, Info CBS Failed to load WCP DLL: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\wcp.dll [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:28:52, Info CBS Failed to load WCP DLL. [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:28:52, Info CBS Failed to initialize the Core DLL: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\\cbscore.dll [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:28:52, Info CBS Failed to initialize CBS class factory. [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:28:52, Info CBS Universal Time is: 2017-07-22 01:28:52.844
2017-07-21 21:28:52, Info CBS Failed to create a worker session [HRESULT = 0x800700c1]
2017-07-21 21:28:52, Info CBS Failed to create worker session. [HRESULT = 0x800700c1]
2017-07-21 21:28:52, Info CBS Failed to get worker session. [HRESULT = 0x800700c1]
2017-07-21 21:29:03, Info CBS Universal Time is: 2017-07-22 01:29:03.136
2017-07-21 21:29:03, Info CBS Loaded Servicing Stack v10.0.14393.0 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\cbscore.dll
2017-07-21 21:29:03, Info CBS Failed to load WCP DLL: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\wcp.dll [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:29:03, Info CBS Failed to load WCP DLL. [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:29:03, Info CBS Failed to initialize the Core DLL: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\\cbscore.dll [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:29:03, Info CBS Failed to initialize CBS class factory. [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:29:03, Info CBS Universal Time is: 2017-07-22 01:29:03.140
2017-07-21 21:29:03, Info CBS Failed to create a worker session [HRESULT = 0x800700c1]
2017-07-21 21:29:03, Info CBS Failed to create worker session. [HRESULT = 0x800700c1]
2017-07-21 21:29:03, Info CBS Failed to get worker session. [HRESULT = 0x800700c1]
2017-07-21 21:29:58, Info CBS Universal Time is: 2017-07-22 01:29:58.395
2017-07-21 21:29:58, Info CBS Loaded Servicing Stack v10.0.14393.0 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\cbscore.dll
2017-07-21 21:29:58, Info CBS Failed to load WCP DLL: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\wcp.dll [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:29:58, Info CBS Failed to load WCP DLL. [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:29:58, Info CBS Failed to initialize the Core DLL: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\\cbscore.dll [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:29:58, Info CBS Failed to initialize CBS class factory. [HRESULT = 0x800700c1 - ERROR_BAD_EXE_FORMAT]
2017-07-21 21:29:58, Info CBS Universal Time is: 2017-07-22 01:29:58.399
2017-07-21 21:29:58, Info CBS Failed to create a worker session [HRESULT = 0x800700c1]
2017-07-21 21:29:58, Info CBS Failed to create worker session. [HRESULT = 0x800700c1]
2017-07-21 21:29:58, Info CBS Failed to get worker session. [HRESULT = 0x800700c1]
Step#1 - SFCFix Script
