[SOLVED] [Win10v1607b14393 x64] 2017-05 Cumulative upd. fails; no problems detected by SFCFIX.
Here is the result:
Start time: 2017-07-18 22:13:10.288
Microsoft Windows 10 Build 14393 - amd64
Using .txt script file at C:\Users\subodhan\Desktop\SFCScript.txt [0]
FileScan::
[0: 1] C:\scratch\CbsCore.dll
File is untraceable.
Found: XseW4amKSxGkLmpdWxOpyS3DU3GR6dflKHShlxLlNPk=
Version number not available.
Trace not available.
[1: 2] C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.82_none_ffc91b1349d62be7\CbsCore.dll
Found: m1K+hqGPF/YRGfwFoPIE2WrtsnWidGDAAPGREVYcG48=
Found: 10.0.14393.0
[C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_dab53140259fad95\CbsCore.dll]
[2: 1] C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb\CbsCore.dll
Found: ll011268+BWnJu9Tgz+4ed9XWraq423//MeY0DTr8NI=
Found: 10.0.14393.0
[3: 1] C:\SFCFix\Backups\C\WINDOWS\Winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.82_none_5be7b69702339d1d\CbsCore.dll
Found: 10.0.14393.0
[4: 1] C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.82_none_5be7b69702339d1d\CbsCore.dll
Found: dN6LMnbAvOKPymsJ6G3PlRDy0VCY15brjhO6AsbVArc=
Currently storing 10 datablocks.
Finish time: 2017-07-18 22:13:12.960
Script hash: bQCg2l2h43sRaI1+Ha1uVb5o1PSFaZ1YxIiTvsk7Lvs=
Please do the following.
2. Open an elevated Command Prompt and run sfc /scannow just like you have in the past.
3. Stop Process Monitor as soon as sfc fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
Step#1 - SFCFix Script
Also, let me know what the name of the folder is within the following path.
C:\windows\servicing\Version
And lastly also do the following.
For the first part of the SFCFix, the output is:
View attachment SFCFix.txt
There are two folders in the path C:\Windows\servicing\version:
10.0.14393.0
10.0.14393.82
For the second part of the SFCFix execution, the output will follow in a few minutes.
Let me know the contents of both of the following folders. Do they both have two files in them?
10.0.14393.0
10.0.14393.82
The folder 10.0.14393.0 is empty.
The folder 10.0.14393.82 has two files:
  1. amd64_installed
  2. x86_installed
OK, I have an idea. Please do the following.
Good. Please do the following again.
SFC Scan
The SFC / scannow failed.
Windows Resource Protection could not start the repair service.
C:\WINDOWS\system32>copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt"
Overwrite C:\Users\subodhan\Desktop\cbs.txt? (Yes/No/All): y
1 file(s) copied.
The cbs.zip is:
View attachment cbs.zip
Can you reboot your computer and try the following one more time?
SFC Scan
If it fails after the reboot please do the following.
SFC /scannow failed again.:
1 file(s) copied.
cbs.zip is below:
I will execute the next command and upload the result in a few minutes.
BrianDrab, thanks so much for spending this time on my issue. Really appreciate it.
Here is the contents of the SFCFix.txt:
Start time: 2017-07-19 22:25:04.178
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_CLASSES_ROOT\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Successfully imported registry key HKEY_CLASSES_ROOT\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Successfully restored ownership and permissions for registry key HKEY_CLASSES_ROOT\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Currently storing 14 datablocks.
Finish time: 2017-07-19 22:25:04.409
Script hash: Bz4oIP3wegF885S66vUvpX7opvIQaI4ymrRubL6BtPs=
Try the following again please.
SFC Scan
The sfc /scannow failed:
1 file(s) copied.
The cbs.zip is below:
OK, please do the following.
