[Win8/8.1] GUIDE: CNBJ2530.DPB and prncacla.inf Corruptions
Re: GUIDE: CNBJ2530.DPB and prncacla.inf Corruptions - Windows 8/8.1
@Squeezer:
You could try to disable it and re-try SFCFIX or the DISM command; LATER, re-enable your security suite, after the procedure finished.
Or you can find the correct version of that file from another machine (same OS, same bit), and substitute it.
Your log shows:
Simplified: "Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}
That should be in C:\Windows\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\cnbj2530.dpb
I'm using Windows 8.1 x64, updated (every updates), and the file should be this (i've uploaded it on speedyshare.com, but scan it however with your antivirus... At least!):
http://speedy.sh/gyVpV/CNBJ2530.DPB
If you are going to try the substitution on your own, but you are unsure on what to do, wait for a reply from administrators/moderators of this forum.
Please don't attempt the replacement yourself, I've got a lot of work to do at the moment but will post a fix for you later :)
Ok thanks Tom, I will patiently wait.
I also have the problems discussed in the previous threads. I downloaded and ran the SFCFix.exe application and it came back with the following text that is listed in the attachment. The part of the log is attached that I could read.
Where do I go from here?
Thanks,
@Squeezer, sorry it took longer than expected but here's your fix:
https://dl.dropboxusercontent.com/u/16537616/Fixes/SFCFix/Scripts/Squeezer/SFCFix.zip
SFC Scan
  1. Click on the Start
@Rickyd53, I've reported the issue to the SFCFix developer but in the mean time let's get some logs:
SFC Scan
Tom
Hello,
I got the same Problem with Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.17415. I used SFCFix.exe and SFCFix.zip as mentioned above for this specific Version. Unfortunatelly I got an Error:
SFCFix version 2.4.3.0 by niemiro.
Start time: 2015-05-22 16:21:00.666
Microsoft Windows Server 2012 R2 Update 3 - amd64
Using .zip script file at D:\tmp\DOES\KB3000850\SFCFix.zip [3]
Failed to determine directive or no lines were entered under this directive.
:: directive failed to complete successfully.
SFCFix version 2.4.3.0 by niemiro has completed.
Finish time: 2015-05-22 16:21:00.759
Script hash: gBad0JhIDbSmFnnm8uzHyvVc3QRo1ZiriYvaNH4yCpg=
[code]
Is it possible to get a new Version of [B]SFCFix.zip [/B]that may run without error?
Thank you very much
Regards
Sascha
It has come to our attention at there has been a recent explosion of people reporting corruptions with the CNBJ2530.DPB file in Windows 8 and 8.1.
This post aims to outline both how to determine whether your computer is affected and how to repair it should it be. Unfortunately, we have yet to identify the root cause for this corruption at this time but it is part of an ongoing investigation here, and we shall be sharing all of our findings with Microsoft when appropriate to lead, if at all possible, to a final resolution.
First, to confirm whether or not you are affected by a corruption of this file, please perform the following:
  1. Press the Windows Key on your keyboard and X to open up the Power User Tasks Menu
  2. Click (or tap) Command Prompt (admin)
    Wait for this to finish before you continue (approximately 15 minutes)
This program, included as standard with all modern copies of Microsoft Windows, will first scan your system files for corruption and will then provide its analysis in a machine friendly form. We shall therefore be using another program, SFCFix (developed here at Sysnative by niemiro) to interpret this data into a more human friendly format.
  1. Download SFCFix.exe and save this to your Desktop.
  2. Save any open documents and close all open windows.
  3. Double click on SFCFix.exe to open it.
  4. Follow all on screen instructions and upon completion, a file should be created on your Desktop: SFCFix.txt.
This logfile will automatically open.
Update 30/06/2014
SFCFix has been recently updated to automatically detect and repair this corruption, making the original guide obsolete. If SFCFix has successfully repaired the corruption, the logfile will contain the following line:
  FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.16384.
The version number will change depending on the version of Windows 8 you are running, but that line signifies that the issue has been successfully repaired. That's it - you're now good to go. If SFCFix reports other corruptions, then please start a thread of your own. Include your CBS folder (per the Windows Update Forum Posting Instructions) and the contents of the SFCFix.txt.
The original guide has been preserved below for reference, and the SFCFix downloads are still available.
If you have any questions regarding this tutorial, let me know. If you are unsure about anything, just ask!
Regards,
Stephen
Last Updated: 30/06/2014 - Changed to reflect recent changes in SFCFix
Hello Tekno,
1st time poster,
I just wanted to say thank you, and all the others here for their help in dealing with this issue. I have been messing with it for days. SFCFix got me sorted. I can't tell you how much I appreciate it! This is a great site, and thanks to all who help others here. I will endeavor to do the same if and when I can. Bookmarked and favorited!
This morning my Toshiba Satellite C50-A-1DV laptop would not boot, it detected a problem before starting windows 8.1 and tried to auto repair. However nothing happened. I booted in safe mode, ran CHKDSK with no errors but SFC /Scannow reported the CNBJ2530.DPB and prncacla.inf corruptions. I downloaded and ran SFCFIX successfully but I still have the same corruptions and the laptop still does not boot. Attached are the SFC details file and the SFC fix text file.
Please can you advise on how I can return my machine to nomal working order?
Many thanks.
Hi,i´m new in forum,I thank those who help me
I used the command SFC /Scannow reported the CNBJ2530.DPB and prncacla.inf corruptions . I used SFCFix.exe and continuous with the error. DISM /online /cleanup-image /restorehealth and continuous the error. I'm using windows 8.1 x64. I put my CBS.log and sfcdetails below
CBS :https://www.dropbox.com/s/boy5399eiqcedef/CBS.zip?dl=0
View attachment sfcdetails.txt
Hi, I again made the command DISM / online / cleanup-image / restorehealth and resolved the issue. Thank without this post I could not have.
Update 30/06/2014
Regards,
Stephen
I followed the instructions above and still have a corrupted file.
Toshiba Satellite P-55 w/i7-4710HQ 16GB RAM
Running WIN 8.1 64 all recent updates installed
Win Defender security (?)
Attempting to do windows update freezes.
Using MS Media creation tool to update to Win 10 error is "Something went wrong"
Attached SFCFix text file and CBS text file
View attachment SFCFix.txtView attachment CBS.txt
View attachment 15108View attachment 15110
So I RTFD, and here is the entire CBS.txt file. View attachment CBS.zip
Just wanted to thank you guys for making that neat little program:thumbsup2:.
avoided windows 8 and 8.1 until about a month ago :banghead: and suddenly the video drivers start crashing. search lead me here, ran the fix program and everything seems to be working again.
>sfc even reporting all clear.
hello,
first time poster
i have the same problem with Amd64\CNBJ2530.DPB being corrupted or something
i am using windows 8, AMD E2-1800 APU 1.70GHz / 4gb ram
i am trying to fix this thing for like a week now, i have run "SFCFix"(which it said it fixed it but when i tried sfc /scannow it was still corrupted), i have run "dism /online /cleanup-image /restorehealth" , i have run "sfc /scannow"
i saw some forums saying i had to replace the corrupted files with new clear ones from a other pc where they are working but i cant do that cose i dont have 1 (and idk where i exacly i can download the specific file)
i just dont know what to do:angry: :banghead:
View attachment CBS.log View attachment sfcdetails.txt
Hey I'm also having trouble with this but it it not the same as mine. Would you be kind to tell me how to solve the problem?:huh:
Hi marisol16 :)
Please start a new thread and attach the CBS.log to your post. A Windows Update Analyst will then assist you.
Thank you.
I have done as the instructions requested but I still have issues on normal boot it freezes on my hp screen. this is my sfcfix.txt if your able to help it would be appreciated.
