[Win8/8.1] GUIDE: CNBJ2530.DPB and prncacla.inf Corruptions
Re: GUIDE: CNBJ2530.DPB and prncacla.inf Corruptions - Windows 8/8.1
I followed your instructions with SFCfix and received the following message -
SFCFix version 2.2.4.0 by niemiro.
Start time: 2014-06-06 12:30:40.522
FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.16384.
CBS & SFC total fixed corruption count: 1
SFCFix version 2.2.4.0 by niemiro has completed.
Finish time: 2014-06-06 12:42:25.009
I then did a further sfc/scannow and do not seem to have a corrupt file, however, does the mention of one, without naming it, in the SFCfix matter?
Very, very grateful, thank you so much.
Betty
Welcome to Sysnative!
It does not matter because SFCFix has successfully repaired it. You're good to go :)
Richard
Can I ask a possibly unrelated query, but as part of the investigation into the problem I had above, I tried to do a restore, however I keep being told there are files missing and I my "windows installation or recovery media will provide these files." I only received the computer back in April after having a new hard drive installed and did make recovery discs, but they are rejected when I try to use them.
Many thanks again.
Betty
I followed the steps in the forum, and have the following log:
Start time: 2014-06-08 04:04:20.844
CBS & SFC total detected corruption count: 4
Finish time: 2014-06-08 04:16:39.067
Any idea how do I go about fixing the remaining files?
Thank you!
Just wanted to say that this fixed my problems for me...
...I had a system image I kept re-installing...and it had no integrity violations at all UNTIL I connected to the Internet.
Now that I've fixed it with the help of SFCFix.exe, I have not had any subsequent problems.
MUCH appreciated.
Stephen, I wanted to thank you for SFCFix downloads. Microsoft wanted to charge me to fix the corrupted files. I am still unable to update windows 8.1. I refreshed my HP Envy laptop about a month ago, and then updated to windows 8.1 again, and now Windows will not update. It gives me error code 8024402F. After following your steps listed above, the scan came back Windows Resource Protection did not find any integrity violations, but I still can't update, do you have any suggestions. I have all my CMD txt if you need to look at them. Any help would be appreciated. Thank you
You're most welcome. Please start your own thread regarding the update issues and follow the instructions here: https://www.sysnative.com/forums/windows-update/4736-windows-update-forum-posting-instructions.html
Stephen
Updated to reflect recent changes in SFCFix.
-Stephen
hi stephen i already followed the guide and the result is this
SFCFix version 2.3.0.0 by niemiro.
Start time: 2014-07-20 19:08:19.030
FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.2.9200.16430.
what should i do next? and is it possible that it was connected to my other problem which that i cant hear any sound even the volume is on from my laptop and i have to shutdown it and open again everytime the sound goes off i do shutoff the laptop and turn it on then sound will be back ..help me to fix this thanks
i scan again using com prompt sf/scannow and it says 100% complete they
didn't find any violation is this good to go? how about my sound/volume are they goin back to normal? i mean it will never goes off like no sound at all ?
I registered just to inform the ts that this solution did it for me. This took me ages to rectify this problem and I'm glad I found it here.
I had the following error after doing sfc /scannow:
PHP:
2014-08-06 07:24:05, Info                  CSI    000006c5 [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB"of prncacla.inf, Version = 6.2.9200.16430, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
2014-08-06 07:24:05, Info                  CSI    000006c7 [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.2.9200.16430, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
2014-08-06 07:24:05, Info                  CSI    000006c8 [SR] This component was referenced by [l:164{82}]"Package_86_for_KB2769165~31bf3856ad364e35~amd64~~6.2.1.0.2769165-12166_neutral_GDR"
After following the procedures carefully as described by the ts, I got the following log:
PHP:
Start time: 2014-08-05 23:43:12.609
Using .zip script file at C:\Users\Series 5\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\windows\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.2.9200.16430_none_fdce12188b615b12\amd64\cnbj2530.dpb
Successfully copied file C:\Users\Series 5\AppData\Local\niemiro\Archive\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.2.9200.16430_none_fdce12188b615b12\amd64\cnbj2530.dpb to C:\windows\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.2.9200.16430_none_fdce12188b615b12\amd64\cnbj2530.dpb.
Successfully restored ownership for C:\windows\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.2.9200.16430_none_fdce12188b615b12\amd64\cnbj2530.dpb
Successfully restored permissions on C:\windows\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.2.9200.16430_none_fdce12188b615b12\amd64\cnbj2530.dpb
SFCFix version 2.3.0.0 by niemiro has completed.
Finish time: 2014-08-05 23:43:13.431
Script hash: IVpRFbNXl/Z9+LrRJnrYu6EUy07Y6EZvkN3AZzSKiRM=
after rescanning (sfc /scannow) using elevated command prompt I received the following message:
Problem fixed.Thanks again TS - very much appreciated. BIG THUMBS UP :thumbsup2:
Now I'm gonna wait and see if this error is causing intermittent audio problems with my headset.
Hello monsterdog, welcome to Sysnative!
Thanks for taking the time to register and say it worked, I'm glad you managed to get it fixed!
Tom
Hello to you all. I have just joined to specifically thank Tekno Venus and other people for arranging this fix. Even as a novice the instructions and the exe were very simple - my compliments. The problem which was annoying me no end is now fixed. All I need now is some dye for my grey hair!
Sincere Thanks To You All.
I shall enjoy reading the rest of the forum and hope to put up some posts.
Many Thanks
Great tool. It saved me a lot of manual work. It worked like a charm on Windows Server 2012 R2 Datacenter.:thumbsup2:
Like many others, apparently, I was getting the "Cannot repair file CNBJ2530.DPB in prncacla.inf" sfc /scannow error on my Win 8.1-64 bit (fully patched) system. Although that was the only error, happy to report after downloading and running sfcfix.exe the corruption was successfully repaired and the scan no longer shows any integrity violations.
Excellent tool, many thanks!
Hi, I found this thread and am glad to report that the downloaded file fixed my ""Amd64\CNBJ2530.DPB" of prncacla.inf" error.
My problem was stated here, in the Microsoft Community Forum: answers.microsoft.com/en-us/windows/forum/windows_8-windows_update/stuck-at-restart-to-finish-installing-updates/043e76a2-6ece-4854-8b82-bc2c4cf06f4d
I ran a System File Check after using your file and it now says that "Windows Resource Protection did not find any integrity violations".
Kudos for creating this tool and making it easily and freely available to the public.
Edit: I have donated a small sum to keep this site running and hope others do so too. :)
Hi, I also had this "Amd64\CNBJ2530.DPB of prncacla.inf" problem, and I was able to fix it with your tool. BUT... Two days later I encountered the same problem again. Any idea how to solve it permanently? Thank you! Uwe
Hello uwulus and welcome to the forum :)
Please follow the instructions Here and we will take a look at your system :)
Hi Guys,
Thanks a lot for this article and the fix, it worked on one of my systems and on the other one combination of few things fixed the same error (I reckon other system had few different issues).
I used this command as well DISM /Online /Cleanup-Image /RestoreHealth
Cheers,
Linda
