version serves to version 6.3.9600.17415 ?
dism /online /cleanup-image /restorehealth
Hi enkelus.:smile9:
If I correctly understood, now sfcfix corrects automatically that problem (using DISM in the background?), hence you could try it.
Anyway, the dism code should work the same:
Code:dism /online /cleanup-image /restorehealth
Personally, I made a copy of that file and a batch file that copies it in the correct folder, and I use it when the problem occurs.
Another workaround I tried (and should work) was to set every users (for that file only) to not write the file.
:wave:
Can anyone tell me why this same corruption keeps coming back? I found it during an SFC /scannnow and used he SFCFix.exe to fix it. All went well for about a month. Then I was having issues again and ran the SFC /scannow again. It once again showed the same file as corrupted AMD/CNBJ2530.DPB. Ran the fix again and it shows it's fixed.
I have windows 8.1 (home) upgrade (got the laptop less than a year ago with Windows 8 and got the free upgrade). Ran a virus scan and malware scan. All clear.
I am far from tech savvy but I wanted to know why it came back again to avoid it in the future.
SFCFix.exe did a perfect job, no corruptions any more.![]()
Thanks for the tools and for sharing it![]()
SFCFix version 2.4.3.0 by niemiro.Start time: 2015-03-01 19:55:27.442
FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.17415.
SFCFix version 2.4.3.0 by niemiro has completed.
Finish time: 2015-03-01 20:20:02.483
Verification 100% complete.
Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.log
[COLOR=#333333][FONT=Segoe UI]Deployment Image Servicing and Management tool
Version: 6.2.9200.16384[/FONT][/COLOR]
[COLOR=#333333][FONT=Segoe UI]Image Version: 6.2.9200.16384[/FONT][/COLOR]
[COLOR=#333333][FONT=Segoe UI][==========================100.0%==========================][/FONT][/COLOR]
[COLOR=#333333][FONT=Segoe UI]Error: 0x800f0906[/FONT][/COLOR]
[COLOR=#333333][FONT=Segoe UI]The source files could not be downloaded.
Use the "source" option to specify the location of the files that are required t
o restore the feature. For more information on specifying a source location, see
[URL]http://go.microsoft.com/fwlink/?LinkId=243077[/URL].[/FONT][/COLOR]
[COLOR=#333333][FONT=Segoe UI]The DISM log file can be found at C:\Windows\Logs\DISM\dism.log [/FONT][/COLOR]
I encountered this issue during general computer maintenance.
My System File Checker failed and I researched thru many Microsoft Community forums and finally found yours with several intelligent professionals that could actually understand the cbs and dism logs.
Could you assist me as well?
SfcFIX
I found this tool on your Windows Update Forum Posting Instructions.
Code:SFCFix version 2.4.3.0 by niemiro.Start time: 2015-03-01 19:55:27.442 Microsoft Windows 8.1 Update 3 - amd64 Not using a script file. AutoAnalysis:: FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.17415. SUMMARY: No corruptions were detected. AutoAnalysis:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.3.0 by niemiro has completed. Currently storing 0 datablocks. Finish time: 2015-03-01 20:20:02.483 ----------------------EOF-----------------------
System File Checker
I ran SFC after SfcFIX and this was produced.
Please see my attached CBS.log file.Code:sfc /scannow Beginning system scan. This process will take some time. Beginning verification phase of system scan. Verification 100% complete. Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.log
CBS.rar
I attempted dism again to ensure everything was corrected...
DISM
Error when running DISM /Online /Cleanup-Image /RestoreHealth - error 0x800f0906
Code:[COLOR=#333333][FONT=Segoe UI]Deployment Image Servicing and Management tool Version: 6.2.9200.16384[/FONT][/COLOR] [COLOR=#333333][FONT=Segoe UI]Image Version: 6.2.9200.16384[/FONT][/COLOR] [COLOR=#333333][FONT=Segoe UI][==========================100.0%==========================][/FONT][/COLOR] [COLOR=#333333][FONT=Segoe UI]Error: 0x800f0906[/FONT][/COLOR] [COLOR=#333333][FONT=Segoe UI]The source files could not be downloaded. Use the "source" option to specify the location of the files that are required t o restore the feature. For more information on specifying a source location, see [URL]http://go.microsoft.com/fwlink/?LinkId=243077[/URL].[/FONT][/COLOR] [COLOR=#333333][FONT=Segoe UI]The DISM log file can be found at C:\Windows\Logs\DISM\dism.log [/FONT][/COLOR]
Please accept my attached dism log file.
Attachment 11008
Just to let you know,
I have run SfcFIX.exe 3 times now and each time I receive the same results.
Code:AutoAnalysis:: FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.17415.
I have read thru the following thread; "Thread: GUIDE: CNBJ2530.DPB and prncacla.inf Corruptions - Windows 8/8.1"
at this point, I am confused. :huh:
Any assistance would be greatly appreciated.
toyotabedzrock
found the answer;
SOLVED: Cannot Install 3.5 On Windows 8.1Error 0x800F0906 and 0x800F081F - Up & Running Technologies Calgary
"DISM /Online /Enable-Feature /FeatureName:NetFx3 /All"
Best of Luck!
