[SOLVED] Window 7 Ultimate Can't Do Microsoft Updates. Help!
Here are the 3 missing manifests.
Remove Update Manually
    wusa /uninstall /KB:2952664
Reboot the machine and try again.
FRST Registry Search
  3. Select the Programs group.
  5. Download the Farbar Recovery Scan Tool and save it to your Desktop:
  6. Right-click on the file FRST64.exe and choose Run as administrator.
  7. Copy and paste KB2952664 into the Search box and click the Search Registry button.
  8. When the scan is complete, a message will display that 'SearchReg.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'SearchReg.txt' to your next reply.
Peter,
The SearchReg.txt is below. Something of interest, maybe, when I opened the windows feature option from the control panel it was unpopulated (no program names, checkboxes, nada). This is not what I remember having occurred at earlier times (months ago now) when last I had opened this feature.
Regards,
Rod
FOF Communications
  3. Press the Fix button.
Click on the Start button and typ in the searchbox CMD.
If CMD is listed above, right-click on it and select Run as administrator.
A command prompt window will open. Copy and paste the following into the command-prompt and hit enter.
dir c:\Windows\servicing\Packages\Package_for_KB2952664*.* > "%USERPROFILE%\desktop\dirlist.txt"
4. After the command runs there will be a file on your desktop named dirlist.txt.
5. Attach this file to your next reply.
Great. Restart the computer.
If it fails, attach the zipped cbs.log to your next reply.
