[SOLVED] Window 7 Ultimate Can't Do Microsoft Updates. Help!
Peter,
The SearchReg.txt for KB3020338 is attached below. It is basically an empty file. Two things to note: 1) The Windows Feature Box was populated this time. The last time this procedure was performed it did not populate. 2) Just to clarify, the cbs.txt file is not automatically generated. I generate it with the command copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt"?
Once again, thank you so much for all your help. I hope we are nearing the end.
Regards,
Rod Wolford
FOF Communications
  3. Select the Programs group.
  6. Copy and paste 6.1.7601.18679 into the Search box and click the Search Registry button.
  3. Press the Fix button.
Reboot the machine.
Try to install KB3172605 only.
If it fails attach the file C:\Windows\Logs\CBS\cbs.txt to your next reply.
Peter,
The KB3172605 update installed successfully! Attached is the fixlog.txt that shows the successful removal of the two registry items. Seems progress has been made.
Regards,
Rod Wolford
FOF Communications
Nice. Try to install KB4474419 only.
Peter,
After I sent the above message, I thought you might also want a FRST registry scan for KB4474419, attached below.
Regards,
Rod
FOF Communication
FRST Registry Search
  6. Copy and paste KB3033890 into the Search box and click the Search Registry button.
Peter,
The install of KB3033890 using the link you provided failed with the message that "some updates were not installed Security Update for Windows (KB3033890)."
Regards,
Rod
FOF Communications
Provide the Components Hive
4. The file will likely be too large to upload here so please upload to Filedropper or WeTransfer and just provide the link here.
  • Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Filedropper or One Drive or WeTransfer and then just provide the link in your reply.
Reboot the machine.
Peter,
Here are the fixlog.txt and cbs.txt. While it is probably not important the failure code from the installer is 80073712.
Regards,
Rod
FOF Communications
Reboot the machine.
Reboot the machine.
Peter,
Pleased to report another victory for you. The install of KB4474419 was successful! Attached is the Fixlog.txt.
Regards,
Rod
FOF Communications
