[SOLVED] Windows 7 32 system restore not working sfc and Sur ok
Why where the 2 log files cut into 2 parts ?
Some valuable information got lost.
  3. Press the Fix button.
Ran latest Fixlist, reason there were 2 parts , it posted addition.txt which I cut to hard drive and it then added a 2nd txt same with FRST.txt
I have redone the scan attached with fixlog.
Download
AS SSD Benchmark.zip.
Right-click the ZIP file and select "Extract all...".
In the extracted folder, click AS SSD Benchmark to start the tool.
Click Start at the bottom of "AS SSD Benchmark".
When finished, click "File - Screenshot" and save the file.
Upload the saved file to a file sharing site and provide the download link in your next reply
Ran ssd benchmark screenshot attached
Instead of system restore lets have a look at another issue that is reported in the logs.
When done with that I suggest to try the upgrade again.
Ran latest fixlist log attached, there is still a problem as well with Chkdsk inside windows image attached or what happens all I get is this text displayed and nothing further ,as you know it works fine if you set it to run on a reboot . Wonder if the this and the system restore problem are related
  • Fixlog.txt
    Fixlog.txt
Yes, probably.
I made a typo in the previous fix.
Great. Perform a FRST scan again.
FRST Scan:
  1. Right-click to run the tool as administrator. When the tool opens click Yes to disclaimer.
  2. Note: Ensure that the Addition.txt check box is checked at the bottom of the form within the Optional Scan area.
  3. Press the Scan button.
  4. Please wait for the tool to finish. It will produce two logfiles called FRST.txt and Addition.txt in the same directory the tool is run from (which should be the desktop)
  5. Post the logfiles FRST.txt and Addition.txt as attachment in your next reply.
Wait a day, then perform a new scan with FRST and post the 2 log files.
Ran FRST scan same problem error 19 when trying to save a restore point , same problem when windows updated so had to reboot and turn off system restore for windows to update ,I also remember had a problem with windows media player if that helps ,had to install MPE? player to get it to work
The registry issue with "Microsoft Works" no longer occurs.
Try system restore again and report the result.
