[SOLVED] Windows 7 32 system restore not working sfc and Sur ok
  3. Press the Fix button.
Restart the machine.
Try system restore again and report the result.
If it fails run a scan with MTB again as in message #97
The errors with system restore seem to be gone so we could fix it partially.
FRST Registry Search
  3. Select the Programs group.
  4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog.
  5. Right-click on the file FRST.exe and choose Run as administrator.
  6. Copy and paste Zune Bus Enumerator Driver;{e707ea47-d8e8-11eb-a788-806e6f6e6963} into the Search box and click the Search Registry button.
Does system restore complete if the USB device as drive I: is disconnected ?
Does system restore complete if the Avast real-time protection is disabled ?
Please answer the 2 questions from my previous post.
Perform a new FRST scan:
  1. Right-click on FRST.exe and select "Run as administrator".
  2. Note: Ensure that the Addition.txt check box is checked at the bottom of the form within the Optional Scan area.
  3. Press the Scan button.
  4. Please wait for the tool to finish. It will produce two logfiles called FRST.txt and Addition.txt in the same directory the tool is run from (which should be the desktop)
  5. Post the logfiles FRST.txt and Addition.txt as attachment in your next reply.
Run scan took about 40 minutes logs attached
That is no problem. It completed successfully.
Open Device Manager.
Open Storage volume shadow copy and delete the entry Generic volume shadow copy.
Try to create a restore point again and report the result.
Hi, the only time Storage volume shadow copy appears currently is when I try and create a restore point when it pops up about 30 seconds after hitting the create button. I uninstalled the generic volume shadow copy which appeared with an error message and both entries dissapeared.
If system restore still fails provide a screen shot of the error message when uninstalling the "generic volume shadow copy".
Hi,it does not show a message if I uninstall the volume shadow copy which pops up it shows code 19 error and then disappears when I uninstall it and the storage volume shadow copy also disappears . creating green line stops and if you go back to the system protection display it is all greyed out.so you must reboot before it then displays in the system protection correctly.
Perform a disk defragmentation on drive C: and report the result.
Ran defrag said disk was 2% fragmented and defragmented drive , the drive is an ssd FYI
