[SOLVED] Windows 7 32 system restore not working sfc and Sur ok
Restart the machine.
Try to create a restore point again.
If it fails do following.
  3. Press the Fix button.
FRST Scan:
Try to create a restore point and report the result.
Ran latest fixlist log attached , still getting code 19 when trying to save a restore point.
Had to update Easeus Todo backup today and now will not back up the drive , stalls at 93% and then freezes the screen . Is this due to the update do you think or the problem I have. If I keep system restore on produces the code 19 in generic volume , turn system restore off stalls at 93%. Any ideas of a back up software? I used to have acronis and that now will not install or run so need a way of backing up the drive while this problem is happening.
Same thing happens after a clean boot: How to perform a clean boot in Windows ?
Does Easeus Todo produce a log file we can have a look at ?
If Easeus Todo backup and system restore both fail at 93% it might be related but I'm not sure.
Hi, tried doing clean boot and making a restore point still code 19 in generic volume . uninstalled ease us todo back up and scanned again
Open Device Manager.
Select and open Generic volume shadow copy.
On the "General Properties" tab, click "Troubleshoot" to start the troubleshooting wizard.
Click "Uninstall", and then click "Scan for hardware changes" to load a usable driver.
Provide a screenshot of the result.
Ran instructions as above images attached
Select Generic volume shadow copy.
Right-click Generic volume shadow copy then click "Uninstall".
When completed click "Scan for hardware changes" to load a usable driver.
Hi, opened device manager generic volume shadow copy shown , tried to create restore point after 15 seconds generic VSC appeared , clicked uninstall and it dissapeared scanned for hardware changes and generic VSC reappeared with code 19
MiniToolBox Scan:
Note: Save all your work and close all programs!
Rightclick "MiniToolBox" and select "Run as administrator".
If you see the startup message "Are you sure you want to continue?" select Yes.
Put a checkmark at Select All.
Click "Go".
When the scan is finished a log file with the name "MTB.txt" will appear on your desktop.
Attach this log file to your next reply.
FRST Search
  1. Right-click on the file FRST.exe and choose Run as administrator.
  2. Copy and paste SearchAll:UimBus;Uim_DEVIM into the Search box and click the Search Files button.
  3. When the scan is complete, a message will display that 'Search.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'Search.txt' to your next reply.
  4. You may close any remaining open windows now.
