[SOLVED] [WinServer2012 x64] WU 80070246. DISM Error: 582 illegal character was encountered.
This has been done. My results are below;
Start time: 2017-08-29 12:30:13.247
Microsoft Windows Server 2012  - amd64
Using .txt script file at C:\Users\Administrator\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7.
Finish time: 2017-08-29 12:30:13.310
Script hash: pbSS6BgSZRdpqNpOcpRB9fhPzxQ2apLzDhJt5K6PwPE=
Let me know if you need anything else, Thanks again!!
DISM /RestoreHealth Scan
Command has been ran. I received the same Error: 14005 The manifest file contains one or more syntax errors. The CBS log has been zipped and attached. Thanks!
Here are the results. Thanks!
Start time: 2017-08-29 19:58:16.807
Using .zip script file at C:\Users\Administrator\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7.manifest
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\winsxs\Manifests\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7.manifest to C:\Windows\winsxs\Manifests\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7.manifest.
Failed to reset file attributes for file or folder C:\Windows\winsxs\Manifests\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7.manifest with error code ERROR_ACCESS_DENIED.
Successfully restored ownership for C:\Windows\winsxs\Manifests\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7.manifest
Successfully restored permissions on C:\Windows\winsxs\Manifests\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7.manifest
Finish time: 2017-08-29 19:58:16.964
Script hash: Pgq5adTarb34qVk4z5TCO3ejjVufgcE7EPNNRdlbt0A=
Command has been ran again and I received the same Error: 14005 The manifest file contains one or more syntax errors. The CBS log has been zipped and attached. Thanks!
Please do this once again:
SFC Scan
CBS log is attached and results are below from the SFCFix.exe. Thanks again!
Start time: 2017-08-31 08:56:34.519
FileScan::
[0: 1] C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16384_none_622908ad510eb05b\cmipnpinstall.dll
File is untraceable.
 Found: zI6em3F0Tm3x3PpQe/aqxiaMUCycqDyeDZGngIhaOEQ=
 Found: 6.2.9200.16384
Trace not available.
[1: 2] C:\Windows\System32\cmipnpinstall.dll
 [C:\Windows\WinSxS\amd64_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_cdf77cd0cd5e1ddd\cmipnpinstall.dll]
[2: 1] C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16384_none_060a6d2998b13f25\cmipnpinstall.dll
 Found: BxC43SamF05GPz1Y7UtN6rggjO1wf45gllNUz53iR6k=
[3: 2] C:\Windows\SysWOW64\cmipnpinstall.dll
 [C:\Windows\WinSxS\x86_microsoft-windows-pnpplugininstaller_1122334455667788_6.2.9200.16384_none_71d8e14d1500aca7\cmipnpinstall.dll]
[4: 5] C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16455_none_062bdf1d989801d0\cmipnpinstall.dll
 Found: /cyn6wjOjjt37i5iAquPkWoQ0J1e2q55EpfkvcAddos=
 Found: 6.2.9200.16455
 [C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16683_none_0609729198b21d43\cmipnpinstall.dll]
 [C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.17280_none_0606535398b4f643\cmipnpinstall.dll]
 [C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.17516_none_06580a359876c22b\cmipnpinstall.dll]
 [C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.17074_none_0615209b98a94560\cmipnpinstall.dll]
[5: 1] C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16455_none_624a7aa150f57306\cmipnpinstall.dll
 Found: AbdtTDGeHY3diX956XrpSqHf3ZbXZMSt6FDZG7IN4Cg=
[6: 1] C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.21913_none_62fd475869f47e9b\cmipnpinstall.dll
 Found: EBhPED8kON/UFGhmHxz0maTbax/s4rOMBqQzuLBXEpc=
 Found: 6.2.9200.21193
[7: 1] C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.21193_none_06881d44b1d803b5\cmipnpinstall.dll
 Found: 4HAgH3dRO+3stp4tuQwF1UTa01cXrbG5ILFJdD5kbkc=
[8: 1] C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.21193_none_62a6b8c86a3574eb\cmipnpinstall.dll
[9: 1] C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.17074_none_6233bc1f5106b696\cmipnpinstall.dll
 Found: BfSmck1RcBygElVamowwfgUiuY0Rfx7/GY7wTwRDaE4=
 Found: 6.2.9200.17074
Finish time: 2017-08-31 08:56:38.368
Script hash: 1DPqOM43McIFIQ2a9z+nLdfMVEwo4oQkq6mHzfQRc7I=
2. Attempt to run DISM just like you have in the past.
3. Stop Process Monitor as soon as DISM fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this into your next post for me to analyse please - put tags around the log to break up the text.
This is completed. I also ran DISM /ONLINE /CLEANUP-IMAGE /RESTOREHEALTH as I figured that will be my next step. CBS log is attached. Thanks!
Start time: 2017-08-31 21:09:56.008
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-pantherengine_31bf3856ad364e35_6.2.9200.16384_none_aabc7b71773d7c95.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-pantherengine_31bf3856ad364e35_6.2.9200.16384_none_aabc7b71773d7c95.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-pantherengine_31bf3856ad364e35_6.2.9200.16384_none_aabc7b71773d7c95.
Finish time: 2017-08-31 21:09:56.773
Script hash: bykHFGvYFcG9o2DMR7qPQkOsc+RgGHZ+zw8q9V/nLQs=
Start time: 2017-09-01 19:50:37.808
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-packagemanager_31bf3856ad364e35_6.2.9200.16384_none_e982cffcc4ab0a68.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-packagemanager_31bf3856ad364e35_6.2.9200.16384_none_e982cffcc4ab0a68.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-packagemanager_31bf3856ad364e35_6.2.9200.16384_none_e982cffcc4ab0a68.
Finish time: 2017-09-01 19:50:38.574
Script hash: 6KVqHV+21CGT8acwN+DiMK4ZTo82czJSYAfv220cqi4=
I went ahead and ran dism again while proc man was running. I received ERROR 14005 again. CBS is attached, here is a link to the logfile.pml https://netorg2466719-my.sharepoint...abf0f1e7dd336&authkey=AQzZg_2w60Uk6OCGs2AGR-0
