[7SP1Pro x64] On Screen Keyboard (OSK) not starting
Re: Win 7 X64 SP1 On Screen Keyboard (OSK) not starting
Magdalene, my advice is we put this thread on hold for the time being. Start a thread in the Windows Update forum to get the system files resolved. First, you will need to run SURT; a link is in the Posting Instructions there, step #3. Afterward, rerun SFCFix and attach new results, along with CBS.log in a thread you create. The specialists there will be able to get the corruptions fixed.
What caused the corruptions is the question. My first suggestion is to go to the Security Arena forum and ask for a checkup after following the Posting Instructions there. My second concern is if you are using any file cleaners. Some are too robust and can damage/delete system files if the wrong things are checked off to be cleaned. The only one, I trust, is the default setting of Ccleaner plus uncheck MS Search in Applications/Windows. I don't run it too often, either. Don't run any for now, until things get back on par.
Limit your threads to one at a time. If needed, respective specialists will redirect you, as I am suggesting here. Finally, dont do any of my suggestions yet, until plodr weighs back in on this thread. I always follow her lead.
Satrow, I vaguely recall you providing that insight on another site, several years back. I was comfortable with what you said then, as I still am. I just stored it away in my mind as nothing to ever get excited about. Again, thanks.
Someone looked at the CBS log and found which files are corrupt. Since I know nothing about CBS logs, I'll wait until Brian Drab gives directions on what is the next step. It is above my pay grade at this point.
Hello! I will assist with your corruption issues:
Dropbox - SFCFix.zip
SFC Scan
Retrieve Components Hive
4. The file will likely be too large to upload here so please upload toa file sharing service and just provide the link here.
SFC Scan
Hi Softwaremaniac,
Apologies for delay in getting back to you but have been away.
Have followed your instructions and relevant results on OneDrive via link below.
Thanks again to you all for your help.
https://1drv.ms/f/s!AnDhvaal73o_fLub_RDz4q77CIg
SFC Scan
SFC Scan
Hi Softwaremaniac,
Have tried again and results at link below.
https://1drv.ms/f/s!AnDhvaal73o_gQBZCA60eovBZ4_c
Magdalene.
Select them and hit ok.
Tried with Tablet PC Components selected and not selected but still unable to start OSK.
Don't know whether any help but tried using Process Monitor and managed to get a log file of activity when a filter of C:\Windows\System32\OSK.exe is applied.
Not really familiar with this program but worth a try.
Click on link.
https://1drv.ms/u/s!AnDhvaal73o_gQJDSxtxQaQJydfG
Magdalene.
