Sysnative Windows Update
Inactive
- Oct 9, 2014
- 741
Re: Win 7 X64 SP1 On Screen Keyboard (OSK) not starting
What happens when you try to install it?
Here you go.GSmartControl
- Download GSmartControl and save it on your Desktop;
- Execute gsmartcontrol.exe; Let the install complete and launch the programme.
- Identify your drive in the list, and double-click on it to bring up it's window (usually you'll find your drive by it's size or it's brand name);
- Go in the Perform Tests tab, then select Extended Self-test in the Test type drop-down list and click on Execute (this test can take a few hours to complete);
- Once the test is over, the results will be displayed at the bottom of the window. Please copy and paste these results in your next reply;
- Also, go in the Attributes tab and if you have any entries highlighted in red or pink, take a screenshot of the GSmartControl window and attach it in your next reply;
View attachment 35390View attachment 35391View attachment 35392Here you go.GSmartControl
Please disable the Lync Add-On in IE and see if the OSK will work.
I'm slowly running out of ideas. Can you run both SFC and SURT again please?
View attachment 35646View attachment 35647I'm slowly running out of ideas. Can you run both SFC and SURT again please?
Here you go.
Magdalene
Here you go.
Magdalene
Just noticed that osk.exe appears in Task manager when invoked from Ease of access. It shows in both Applications and processes tabs as running.
Then when I click on Ok in the Pop-up box 'Could not start On screen keyboard' they disappear from Task manager.
Is this of any help to you as it confuses the hell out of me !
Magdalene.
There is a possibility that when OSK starts, it looks for some library (dll) code and isn't finding it. Let's restore your redistributable runtimes. There is a very quick and easy tool that will do this. Download Visual C++ Runtime Installer (All-In-One) - MajorGeeks
Read what Tim wrote about it and run the video, he has there. Download and run the installer after creating a restore point. Since we don't know which runtimes are the problem, just install them all. Here is some background info on what these are. Why Are There So Many “Microsoft Visual C++ Redistributables” Installed on My PC?
