[7SP1Pro x64] On Screen Keyboard (OSK) not starting
Re: Win 7 X64 SP1 On Screen Keyboard (OSK) not starting
View attachment SFCFix.txtView attachment SFCFix.txt
Dropbox - SFCFix.zip
Here you go.
Magdalene.
View attachment 35340View attachment 35340
SFCFix is reported as unreadable\corrupt when run.
magdalene
Here you go.
Magdalene.
Extract the files from the zip and copy everything from the winsxs folder to the C:\Windows\winsxs folder if you can.
Boot to Clean Boot mode and retry. Something must be blocking it, because I can download and use the fix just fine.
No dice clean boot. Same result.
Compressed a large file and downloaded to myself and extracted to desktop OK.
Magdalene.
