Please do following:
FRST Registry Search
- Click your Start button and choose Control Panel.
- In the upper right corner ensure the View by: is set to Category.
- Select the Programs group.
- Click the Turn Windows features on or off link. This will bring up the Server Manager dialog.
- Right-click on the file FRST64.exe and choose Run as administrator.
- Copy and paste KB4507437 into the Search box and click the Search Registry button.
- When the scan is complete, a message will display that 'SearchReg.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'SearchReg.txt' to your next reply.
- You may close any remaining open windows now.
