Thanks. Also, I stumbled upon this as I was Googling how to reverse registry changes by malware. If you get a chance, take a look and let me know your thoughts. I don't know how reliable they are as I've never heard of any of them before. 8 Tools to Restore Task Manager, Regedit, CMD and Folder Options After Being Disabled by a Virus • Raymond.CC
You can also add to that list:
  • Wise Pc first aid - free for personal use (wisecleaner.com)
  • RegSeeker - free for personal use (hoverdesk.net)
  • kerish doctor - only paid - free trial for 15 days
Please do the following.
Step#1 - FRST Fix
Note. It's important that both files, FRST and fixlist.txt are in the same location or the fix will not work (in this case...the desktop).
2. Run FRST by Right-Clicking on the file and choosing Run as administrator. In your case it may already be open.
4. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post the contents of it in your reply.
Thank you xilolee. Will keep these in mind.
Fix result of Farbar Recovery Scan Tool (x86) Version: 02-07-2016
Ran by Joe (2016-07-03 10:13:50) Run:13
Running from C:\Users\Joe\Desktop
Loaded Profiles: Joe & (Available Profiles: Joe)
Boot Mode: Normal
fixlist content:
cmd: dir "C:\System Volume Information\SystemRestore\FRStaging\Windows\winsxs\x86_microsoft-windows-i..l-keyboard-00000454_31bf3856ad364e35_6.1.7600.16385_none_e86c9e10c4b0dcb5"
cmd: dir c:\windows\winsxs\x86_microsoft-windows-i..l-keyboard-00000454_31bf3856ad364e35_6.1.7600.16385_none_e86c9e10c4b0dcb5
========= dir "C:\System Volume Information\SystemRestore\FRStaging\Windows\winsxs\x86_microsoft-windows-i..l-keyboard-00000454_31bf3856ad364e35_6.1.7600.16385_none_e86c9e10c4b0dcb5" =========
Volume in drive C has no label.
Volume Serial Number is 149B-5E56
Directory of C:\System Volume Information\SystemRestore\FRStaging\Windows\winsxs\x86_microsoft-windows-i..l-keyboard-00000454_31bf3856ad364e35_6.1.7600.16385_none_e86c9e10c4b0dcb5
06/18/2016 02:38 AM <DIR> .
06/18/2016 02:38 AM <DIR> ..
0 File(s) 0 bytes
2 Dir(s) 806,612,729,856 bytes free
========= dir c:\windows\winsxs\x86_microsoft-windows-i..l-keyboard-00000454_31bf3856ad364e35_6.1.7600.16385_none_e86c9e10c4b0dcb5 =========
Directory of c:\windows\winsxs
File Not Found
==== End of Fixlog 10:13:51 ====
Please do the following. The resulting file will be a little large so go ahead and attach it.
Step#1 - FRST Fix
1. Download fixlist.txt and save it to the Desktop.
Still fixing after about 25 minutes. FRST has never taken so long before but maybe it's because this is an especially big fix? Or is something preventing it from completing?
Wow, that's huge. Still fixing after about 45 minutes but I guess let's keep it going. What's the longest it's taken from your experience?
According to the log it's about half done and is working as expected. After it's completed we should get another scan.
SFC Scan
  1. Click on the Start
Also, one way to ensure that the process is still running is to open up the log file and look at the last line. As long as the last line doesn't match the following then it's running.
=========  echo n | xcopy "C:\System Volume Information\SystemRestore\FRStaging\Windows\winsxs\x86_microsoft-windows-m..do-backcompat-tlb28_31bf3856ad364e35_6.1.7601.17514_none_ecc8167e5098bf91" c:\windows\winsxs\x86_microsoft-windows-m..do-backcompat-tlb28_31bf3856ad364e35_6.1.7601.17514_none_ecc8167e5098bf91\ =========
Thanks. I'll continue to keep an eye on it. Hopefully it will finish soon.
Btw, I'm poking around in my registry and looked under hkey_users. I've never had as many SIDs as I do now. What are the chances I've been/am hacked?
I'd be interested to look at that at some point. From looking at your logs I doubt it though. If you suspect that someone as infiltrated your system, the only way to guarantee that it's not infected is to do a clean install but we'll cross that bridge later if we have to.
