Step#1 - SFCFix Script
Then repeat the steps in Post#14.
Here is the SFCFix log:
Start time: 2016-06-26 16:00:26.582
Using .txt script file at C:\Users\Joe\Desktop\SFCScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\3a82b417fc202847dc59f1a5a9b537ad11592a101c04f5b9a763584203207000.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\3a82b417fc202847dc59f1a5a9b537ad11592a101c04f5b9a763584203207000.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs.
Currently storing 227 datablocks.
Finish time: 2016-06-26 16:00:27.019
Script hash: IrQQoFIB0g9+3Lg/6gx7qPVumIsROi/JXfXO+tEPXOI=
The update still wouldn't install. Here is the updated CBS log:
CBS.log - Google Drive
Thanks and sorry this is has been so difficult.
No problem. We actually got a little further this time. Let's do this again.
2016-06-26 16:02:39, Error                 CSI    000006c5@2016/6/26:20:02:39.822 (F) d:\win7sp1_gdr\base\wcp\componentstore\storelayout.cpp(11690): Store corruption detected in function ComponentStore::CRawStoreLayout::CheckFamilyIndexForDeadWinnerComponent expression: (null)
  MissingWinningComponentKey on resource [79]"x86_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.19146_none_abbbde0bb8df3b7e"[gle=0x80004005]
Start time: 2016-06-26 19:24:59.582
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.19146_none_abbbde0bb8df3b7e.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\361e9eedcdfbd503697611e204d634114318554aa7eb1ca3c0ae5253bb8aeca2.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\32bc53731d9..b166de0a3b7_31bf3856ad364e35_6.1.7601.19146_ff98c13943acf758.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.19146_none_abbbde0bb8df3b7e.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\361e9eedcdfbd503697611e204d634114318554aa7eb1ca3c0ae5253bb8aeca2.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\32bc53731d9..b166de0a3b7_31bf3856ad364e35_6.1.7601.19146_ff98c13943acf758.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Thanks again
Currently storing 230 datablocks.
Finish time: 2016-06-26 19:25:00.269
Script hash: n/i4ApyGaFnlmNy1ooZhnrYXsYA6csLbGxstjtdgJNc=
SFC Scan
  1. Click on the Start
That update does show as needing to be installed along with the five others I mentioned in my first post. Also showing is one optional update I selected - KB3161608.
I still can't install any of them, either manually or through WU.
Thanks
Here you go:
I don't know if this info is helpful but when I try to manually install the update, I get "initialization, installation...done!" but it keeps failing on "installing security update."
Thanks again
I have an idea but need fresh copies of your hives.
Retrieve Components/Software Hives
Note: The Software have has confidential and sensitive information in it so please send me a PM with a link to that particular hive so it's not in the public form.
  • Open up the RegBack program that should already be installed.
  • This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, two of which are named COMPONENTS and SOFTWARE.
  • Copy these two files to your Desktop. If the COMPONENTS file does not exist, please fetch it instead from C:\Windows\System32\config\COMPONENTS.
  • Now right click on these files on your desktop and select Send to > Compressed (zipped) folder.
  • Then please upload the zip file(s) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Dropbox or One Drive or SendSpace and then just provide the link in your reply.
Thanks. Please let me know the results of the following.
Remove Update Manually
wusa /uninstall /KB:3140735
Through command prompt I received the following error: Windows Update Standalone Installer - "installer encountered an error 0x800736b3. The referenced assembly is not installed on your system."
Then I tried to install through my control panel and received the following error: Windows Update - an error has occurred. Not all of the updates were successfully uninstalled."
That's what I expected. Please do the following.
Step#2 - SFC Scan
Items for your next post
1. SFCFix.txt
2. CBS.txt
Start time: 2016-06-27 15:15:40.385
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-gdi_31bf3856ad364e35_none_fb4f313c7e91933e\6.1.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-gdi_31bf3856ad364e35_none_fb4f313c7e91933e\6.1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-gdi_31bf3856ad364e35_none_fb4f313c7e91933e\6.1.
Currently storing 231 datablocks.
Finish time: 2016-06-27 15:15:41.414
Script hash: 7FGNAfTvfJI7bnz7ShnEAv8wN+icwz3tCdHVjCmmdYk=
I just wanted to give you a heads up and not leaving you hanging...I'm going to need to be offline for the next few hours but as soon as I get back to my desktop around 7pm EST I'll run the sfc /scannow for you.
Thanks for all your help. You've been great. Hopefully we're getting near the finish line.:smile9:
