Making progress! Please do the following.
Step#1 - SFCFix Script
Step#2 - SFC Scan
  1. Click on the Start
Items for your next post
1. SFCFix.txt
2. CBS.txt
Here is the SFCFix log:
Start time: 2016-06-27 22:01:27.857
Using .txt script file at C:\Users\Joe\Desktop\SFCScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-smb20-minirdr_31bf3856ad364e35_none_f41a2eb2cea6f664\6.1.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-smb20-minirdr_31bf3856ad364e35_none_f41a2eb2cea6f664\6.1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-smb20-minirdr_31bf3856ad364e35_none_f41a2eb2cea6f664\6.1.
Currently storing 232 datablocks.
Finish time: 2016-06-27 22:01:28.653
Script hash: CnLEn+1SgU3YmBreh9m8A8BtRZ+NNmkszU/xYqI1FTA=
Windows Resource Protection found corrupt files and successfully repaired them. Here is the CBS log:
CBS.log - Google Drive
Thanks
Update: I was also able to install KB3164035 manually. The rest of the updates continue to fail with error 8007312.
Thanks for the update. We need to take one at a time. Please use Windows Update to attempt the install of only KB3161561.
When it fails, please send me the c:\windows\logs\cbs\cbs.log
Thanks.
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
Start time: 2016-06-28 15:09:29.805
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-security-credssp_31bf3856ad364e35_none_75190de1af9080a1\6.1.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-security-credssp_31bf3856ad364e35_none_75190de1af9080a1\6.1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-security-credssp_31bf3856ad364e35_none_75190de1af9080a1\6.1.
Currently storing 233 datablocks.
Finish time: 2016-06-28 15:09:30.656
Script hash: 0EDMyDezouImwI9VGjSqdp6h6bd+nieT05YeyiPmaCI=
Thanks
We got closer based on the log. Please do the following.
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
Start time: 2016-06-28 21:49:47.861
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-cryptbase_31bf3856ad364e35_none_88c0c64358da105d\6.1.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-cryptbase_31bf3856ad364e35_none_88c0c64358da105d\6.1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-cryptbase_31bf3856ad364e35_none_88c0c64358da105d\6.1.
Currently storing 234 datablocks.
Finish time: 2016-06-28 21:49:48.823
Script hash: 547ImbmYELLI5wNwRIonDfHnjo/lnZ9nSo5b35nLNkU=
Thanks
We are further. It's the following component now that we need to adjust.
x86_microsoft-windows-security-kerberos
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
Start time: 2016-06-29 12:35:39.707
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-security-kerberos_31bf3856ad364e35_none_acde65fb3c17e2f2\6.1.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-security-kerberos_31bf3856ad364e35_none_acde65fb3c17e2f2\6.1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-security-kerberos_31bf3856ad364e35_none_acde65fb3c17e2f2\6.1.
Currently storing 235 datablocks.
Finish time: 2016-06-29 12:35:40.447
Script hash: cRixNZ+HVGQxjGv9oCPqOxd0+9jVLTLznLRQUz03ApY=
I then tried to install KB3161561 and, again, it failed. Here is that subsequent log:
CBS (2).log - Google Drive
Sorry if I jumped the gun by trying again to install the update without your direction - just getting impatient. Hope you understand.
Thanks.
Understood and that's exactly what I would have had you do anyway. Let's fix the next component
x86_microsoft-windows-ncrypt-dll
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
