I plugged directly into a LAN port on my router/disconnected from my wireless and had no disconnects while using it for more than half an hour except when I closed the lid on my laptop and opened it again, but the disconnect was only for ~15 or so seconds, just long enough for the computer to wake up probably.Dee, try these suggestions one at a time and let us know if there's any change with disconnections:
Plug your laptop into one of the 4 LAN ports of your router with a network cable and disconnect from your wireless network. Surf the net and see if there are any disconnects.
I didn't get disconnected after doing either one of the above either. The internet was quite slow, though, and took about 15 to 30 secs to open an email. That's the only thing I noticed.Go into Device manager, right click on the ISATAP device and select disable. Uncheck the box for Internet Protocol version 6 again and leave it off. these can both safely be turned off for now.
I switched back to wireless and waited for a few minutes but my computer didn't automatically connect, so I had to go into 'Connect to a network' and manually click on my network. This was sitting a foot away from the router. Other than that incident, I didn't have any disconnects after using the computer for awhile. Which tells me a lot, but I'll let you tell me in case I'm wrong. :grin1: I don't quite understand how I can have 'excellent' signals from the router elsewhere in the house, though, but still get disconnected. I don't have portable phones or baby monitors. I do have a microwave, but it's rarely on - does it still interfere if it's not in use?If you get disconnected, click the Start Button and type Network & Sharing into the Search box. Click on the Red X in your network map and let Windows troubleshoot the problem. Write down any messages Windows gives. You can try this using only your wired connection and then again using only your wireless connection.
And something else I just noticed. The router is in the den in the basement (so surrounded by cement/concrete foundation), and down here, the Xirrus program isn't picking up the same amount of neighbouring wireless waves as it was picking up when I had it on yesterday in the upstairs' part of the house, which is where I use my laptop 99.9% of the time. Looks like something I'll have to live with though.
Hi jc, Here is the requested zip file. Can you tell me why you want me to remove Superantispyware and Malwarebytes? Thx.
wevtutil gli system >0 & echo ____>>0 & wevtutil gl system >>0 & start notepad 0
wevtutil.exe cl System
echo ** Cleared System Log ** >00 & wevtutil gli system >>00 & echo ____>>00 & wevtutil gl system >>00 & start notepad 00
If it's just a problem with interference I feel bad for making you guys work so hard. :embarrasment5:
Signal : 99%
I requested removal (for now - temporarily) because these apps "phone home" and it is possible that these or other "phone home" apps may be involved, but it seems unlikely. I thought process of elimination may help isolate the cause; however, Please hold off on removing the apps for now.
EDIT: For future reference, your system, Toshiba Support - http://209.167.114.38/support/TechSupport/productcontents/satellite/PSAGCC-02C019.htm
Let me make sure I follow. You were a foot away from the router and your laptop was connected wirelessly, and you didn't have any disconnection problems. Is that correct? Did you still have the ISATAp adapter and IPV6 disabled?
If you can run a network cable from your modem in the basement to a more central point upstairs, you could move your router upstairs... If it turns out to be a signal issue.
Fred said:Re-enable IPV6 and the ISATAP adapter then connect wirelessly when you're right next to the router. Go to speedtest or surf the internet for a while and see if you still disconnect. If you don't disconnect, I'd probably blame the problem on a wireless interference issue.
Now the original xirrus screenshot i know it is deleted showed good signal where was the Laptop then was it near to the router?
Agree with Fred that a lot of concrete between your router and Laptop is going to degrade the wireless signal significantly.
The only problem I had today was getting the laptop to initially connect when I was close to the router. It didn't disconnect after I finally connected, though, but I was only on for about 10/15 minutes.can i ask when your Laptop was close to the router using the wireless did it disconnect.
OK.Leave the isatap adapter disabled it is not required for normal internet connectivity using ipv4.
I won't be able to do that right away because I don't have a long ethernet cable, but I will get one. Thanks for your input CyberMan.Do as Fred advised and test the connection with a long ethernet cable so the router is upstairs and see what the wireless signal is like then and post speedtest results.
Dee, go into Network & Sharing center. On the left side click Manage Wireless Networks then locate the name of your network, right click and delete it. Back in Network and Sharing, refresh the list of wireless networks available, select yours, reenter the password and save the connection.
I can't remember. :lol: But, I'll experiment and see what works best.If disabling IPV6 & ISATAP gets you a trouble free connection then keep them disabled.
I would also check the wireless mode your router is using. It's broadcasting in G band, yet your laptop seems to have an N band network card, which is faster and may offer more stability.
Xirus is picking up 9 different networks in your area - that's a lot. Your foundation is also shielding you from signals outside of your basement.
jcgriff2 said:The Event Viewer System log reset was successful per the attachments in POST 48.
You should see new records -
START | type eventvwr.msc
GZ said:
I also want to point out that any barrier (carpet, wood, drywall) will degrade your wireless signal. Also, electrical interference caused by house wiring, cable and telephone will cause signal degradation as well. Also, copper water piping and such will affect it to a degree too.
