issues adding feature on Server 2016 standard has led CBS errors with KB4598243
Follow these instructions to remove an update.
  • Open the Start menu of Windows and type the command CMD
  • When command prompt opens, copy and paste the following command into it, then press enter.
wusa /uninstall /KB:4048953
  • Let me know if it says it was successful or you get the message: The update KB4048953 is not installed on this computer.
Download the
  • Open the startmenu and type the command cmd.
  • After you find the Command Prompt, right click on it and select Run as Administrator.
  • Copy and paste the following into the Command Prompt and press enter.
Right-click on the file FRST64.exe and choose Run as administrator.
  • Copy and paste the following (code) into the Search box and click the Search Registry button.
KB4048953
  • When the scan is complete, a message will display that SearchReg.txt is saved in the same folder FRST was started from.
  • Post the logfile SearchReg.txt as attachment in your next reply.
Start the
  • Press the Fix button.
Please try to install the backup feature again and let me know the result. If it fails attach a new copy of the CBS logs.
I actually tried to remove it yesterday and it failed but I forgot to include the logs. Here they are.
Download the
  • Copy and paste the following (code) into the Search box and click the Search Files button.
SearchAll: msil_wsbcmdlet*
  • When the scan is complete, a message will display that Search.txt is saved in the same folder FRST was started from.
  • Post the logfile Search.txt as attachment in your next reply.
Afterwards try to uninstall the backup feature again and post the result.
SFCFix ran and I have attached the result file. The uninstall failed with the same error and I have included the CBS logs.
The latest error looks the same, but is slightly different, could you please provide new copy's of the following hive files.
Upload your COMPONENTS hive.
Export CBS (Component Based Servicing) ans SBS (Side By Side) hive through the command line
  • Open the Start menu of Windows and type CMD.
  • When you see Command Prompt on the list, select the option Run as administrator.
  • Copy and paste the following commands one at a time into the command prompt and press enter after each.
REG Save "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing" "%userprofile%\Desktop\CBS.hiv"
REG Save "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide" "%userprofile%\Desktop\SBS.hiv"
  • ZIP both *.hiv files and attach this file as attachment to your next reply.
I performed that and the update failed with the same error code. Here are the results from SFCFix and the CBS logs.
2023-07-10 10:38:05, Error                 CBS    Failed. Attempted to uninstall a version of a non-driver component that is not installed, version: 0Xa000038390000, component: amd64_blbproxy_31bf3856ad364e35_10.0.14393.0_none_87f9b2a082e75508, owner: Microsoft-Windows-BLB-Package~31bf3856ad364e35~amd64~~10.0.14393.0.WindowsServerBackup [HRESULT = 0x80004005 - E_FAIL]
That's a very strange error. System Manager definitely thinks it is installed.
I applied the fix but the error is still the same.
This is absolutely a strange issue, especially since a Process Monitor trace did not reveal the issue(s) in the previous logs? In the latest registry (HIVE) files, I do see that many keys are probably missing, but not when I filter the ProcMon log. Could you please try to uninstall the BU feature again with Process Monitor running, but stop the trace this time after 5 minutes when it fails.
I may need to do this after hours when I can turn off some of the software running on this server. I ran procmon as instructed, but the log file is almost 1GB, compressed.
