[SOLVED] Missing mcf80u.dll and others!
Here is the requested information.
OK great! What about the scantopcactivatioapp.exe application exception error I get when shutting down? I have to click on it to complete shutdown process.
When I open task manager I see this;
Chrome has closed unexpectedly. Nothing to be worried about unless it happens frequently. I will be closing this topic now as we have resolved all Windows Update issues.
It happens every time i try to open a tab. The memory column shows 95% memory used or available?
Should I open a new thread..."upgraded to win.10 everything is funky now?:smile9:
I'm getting crashes in both DAWS. Seems to be a audio driver thing. Funny My sound card and interface I use for recording/playback is working fine in windows sound. But when I try to use in any of my recording/playing Apps it fails/crashes.
I won't bother you any longer. Thank you for all your help Above and beyond!
Ron
Yes... sorry it took so long to reply..I've been trying to deal with my printer problem. Still can't get the software interface to load. It prints wireless, but won't install..go figure!
There is no error other than when I click on the Printer icon in the taskbar..normally (and it was working earlier today) I get the software interface Like ink levels, scan to computer, connect to the web , and so on.
Now I only get a device set-up window that opens to connect a new printer dialog box. When I click the (connect a new printer) button, and select connect a printer wireless, it fails.
Printer is HP Officejet Pro 8620 .
I don't know. Thought I did I used the CD tat came with it however don't get an autorun so I selected the setup.exe file.
