[SOLVED] Missing mcf80u.dll and others!
Yes, had to. I'm writing this in Windows 10 Pro right now.
I don't know how now I guess. When I try the run window goes away! Never mind found it.
SFC Scan
Yea, just one thing tho the desk top seems to be re-setting a lot is this a normal thing for 10?
No PC It may have been trying to keep changing my default browser. I have been selecting it improperly..steep learning curve here.
Lastly! Thank You again!!
Really liking Win. 10 so far. One thing, how do I change the order of my drives and delete the empty folder icon? in pic shown
Also notice Drive F, and G don't show their size and usage. How do I correct that?
I just got a very unstable system. I got a "the exception 0xc0000409 in the application a location 0x0007ff6b. I have duel monitors..the resolution keeps changing..the desktop keeps swapping sides on it's own I get locked out of the desktop by the pointer not moving over to the other screen then it will switch...gees I think I picked up a virus when I was downloading a drive wiper program! I don't know.
Help please. I ran SFC scannow it came up clean. I deleted the AMD catalyst control center for now..
GSmartControl
For now I only want a screenshot of you Attributes tab.
  • Execute gsmartcontrol.exe; Let the install complete and launch the programme.
The Drive is a brand new Samsung 860 EVO . I downloaded a fresh, and updated version of AMD's Catalyst Control Center. The screens have gone back to normal. One thing I did was disconnect the loom to the D drive while power was still on. It didn't seem to harm it as I re connected it and was able to transfer the files to the newly wiped ex-C drive. However, in the process three of the drive connections came loose at once. This created the (what was where) question. Anyway I had to go into the bios and change the boot priority. Everything good there now.
Also The last two times I've downloaded a program I've gotten a widow similar to this.
