SFCFIX : Some corruptions could not be fixed automatically
One of the problems was fixed.
Download
MiniToolBox and save the file on your desktop.
Note: Save all your work and close all programs!
Rightclick "MiniToolBox" and select "Run as administrator".
If you see the startup message "Are you sure you want to continue?" select Yes.
Put a checkmark at Select All.
Click "Go".
When the scan is finished a log file with the name "MTB.txt" will appear on your desktop.
Attach this log file to your next reply.
Uninstall following outdated programs:
  • Java SE Development Kit 7 Update 9 (64-bit)
  • Java SE Development Kit 8 Update 77 (64-bit)
Click the Start button and in the search box, type Command Prompt
When you see Command Prompt on the list, right-click on it and select Run as administrator.
When command prompt opens, copy and paste the following command into it, then press enter.
fsutil hardlink list C:\WINDOWS\System32\sdiagnhost.exe
When completed, take a screenshot of the commandprompt window and paste it into your next reply.
That looks normal.
Yes. Sorry that the attached filename does not match the filename in the instructions but that doesn't matter.
This was the response.
Start time: 2022-09-20 04:00:28.914
Using .txt script file at C:\Users\Admin\Desktop\SFCFix.txt [0]
Trace::
Failed to trace component sdiagnhost.exe with return code 1 and conditional return code ERROR_FILE_NOT_FOUND.
Currently storing 20 datablocks.
Finish time: 2022-09-20 04:00:30.284
Script hash: LPWmGu6s9zv3mOGksL0GSRKn6UXNj+auf3A1n1HpCOE=
Good.
Start time: 2022-09-20 18:51:47.814
Using .txt script file at C:\Users\Admin\Desktop\SFCFixScript.txt [0]
FileScan::
[0: 2] C:\Windows\WinSxS\amd64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.17415_none_0b30df96304ee82e\sdiagnhost.exe
Expected: UNKNOWN Found: SAqvv3N4av2ylfHbTizCbOli7vs4ZpwUZyWQxeEaPFo=
Expected: 6.3.9600.17415
Successfully traced component amd64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.17415_none_0b30df96304ee82e.
Package_873_for_KB3000850~31bf3856ad364e35~amd64~~6.3.1.8.3000850-2600_neutral_GDR4
[C:\Windows\System32\sdiagnhost.exe]
[1: 2] C:\Windows\WinSxS\wow64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.17415_none_158589e864afaa29\sdiagnhost.exe
Expected: UNKNOWN Found: u/bZ7SZk9r/M5ANIoMvXPFW6NkzshkmyvzMuMwHtehk=
Successfully traced component wow64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.17415_none_158589e864afaa29.
Package_1610_for_KB3000850~31bf3856ad364e35~amd64~~6.3.1.8.3000850-4807_neutral_GDR4
[C:\Windows\SysWOW64\sdiagnhost.exe]
[2: 1] C:\Windows\WinSxS\amd64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.20512_none_0bb7924b496f2252\sdiagnhost.exe
Expected: UNKNOWN Found: YorCyAvtQeot8Q359QhL15g0Rkgdp4Bs6RskoXVsKaw=
Expected: 6.3.9600.20512
Successfully traced component amd64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.20512_none_0bb7924b496f2252.
Package_832_for_KB5008263~31bf3856ad364e35~amd64~~6.3.1.9.5008263-1308_neutral2
[3: 1] C:\Windows\WinSxS\wow64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.20512_none_160c3c9d7dcfe44d\sdiagnhost.exe
Expected: UNKNOWN Found: UVhSfuwkWKxUBUlxkHRyzsopy4JXa/kOlxMTiHncM/w=
Successfully traced component wow64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.20512_none_160c3c9d7dcfe44d.
Package_1257_for_KB5008263~31bf3856ad364e35~amd64~~6.3.1.9.5008263-2088_neutral2
Finish time: 2022-09-20 18:51:57.180
Script hash: WmsdklPkWkc8pld34MsK0GqhpTKLFfHYYCjaido/J6k=
Provide the Components Hive
4. The file will likely be too large to upload here so please upload to Gofile or WeTransfer and just provide the link here.
  • Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Gofile or WeTransfer and then just provide the link in your reply.
Is there anything additional i can be doing to try and solve the components issue?
Sorry for the delay.
Remove Updates Manually
  3. When command prompt opens, copy and paste the following command into it, then press enter after each.
    Note: Wait for the command to complete before executing the next one.
    wusa /uninstall /KB:KB5012670
    wusa /uninstall /KB:KB5014738
    wusa /uninstall /KB:KB5015874
    wusa /uninstall /KB:KB5017367
When i enter it, i get a Windows Update Standalone Installer popup (image attached). Does this indicate it's run?
Sorry, my mistake. Below the correct commands.
    wusa /uninstall /KB:5012670
    wusa /uninstall /KB:5014738
    wusa /uninstall /KB:5015874
    wusa /uninstall /KB:5017367
  • 5012670 it said 'required by Windows'.
  • 5014738 it said 'not installed on this computer' - it then said only 1 instance of wusa can run at any time so i restarted.
  • 5015874 it said 'not installed on this computer'
  • 5017367 it asked me if i wanted to uninstall it. I said yes and it's uninstalled and restarted.
The pop-up has continued to appear however.
There is more to fix so please be patient.
FRST Registry Search
  3. Select the Programs group.
  4. Click the Turn Windows features on or off link. This will bring up the Server Manager or Windows Features dialog.
  5. Download the Farbar Recovery Scan Tool and save it to your Desktop:
  6. Right-click on the file FRST64.exe and choose Run as administrator.
  7. Copy and paste KB5015874;KB5017367 into the Search box and click the Search Registry button.
  8. When the scan is complete, a message will display that 'SearchReg.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'SearchReg.txt' to your next reply.
