SFCFIX : Some corruptions could not be fixed automatically
  3. Press the Fix button.
Remove Update Manually
    wusa /uninstall /KB:5014738
Fixlog.txt is attached. It's saying 5014738 is not installed when i run the command after fixlog had been completed.
FRST Registry Search
  3. Select the Programs group.
  4. Click the Turn Windows features on or off link. This will bring up the Server Manager or Windows Features dialog.
  6. Copy and paste KB5014738 into the Search box and click the Search Registry button.
I've copied it in below as it's only a single line.
Farbar Recovery Scan Tool (x64) Version: 30-08-2022
Ran by Admin (29-09-2022 17:12:28)
Running from C:\Users\Admin\Desktop
Boot Mode: Normal
================== Search Registry: "KB5014738" ===========
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\KB5014738-MappingPackage~31bf3856ad364e35~amd64~~9600.20402.1.18]
====== End of Search ======
Did you perform step 4 as mentioned ?
Earlier you said:
in event viewer i'm getting an application crash for sdiagnhost.exe (every time i boot up windows).
Does that still happen ?
It was doing, i've run the fixlist.txt file and below is the response. 5 minutes after the restart and it's not yet popped up, i'll respond if/when it does.
Fix result of Farbar Recovery Scan Tool (x64) Version: 30-08-2022
Ran by Admin (29-09-2022 21:39:20) Run:2
Loaded Profiles: Admin
Boot Mode: Normal
fixlist content:
CloseProcesses:
CreateRestorePoint:
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\KB5014738-MappingPackage~31bf3856ad364e35~amd64~~9600.20402.1.18]
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\KB5014738-MappingPackage~31bf3856ad364e35~amd64~~9600.20402.1.18" => removed successfully
The system needed a reboot.
==== End of Fixlog 21:39:35 ====
Restart the machine.
If it happens again perform the instructions in message #31 again.
Start time: 2022-09-30 18:17:47.555
Using .txt script file at C:\Users\Admin\Desktop\SFCFixScript.txt [1]
FileScan::
[0: 1] C:\Windows\WinSxS\amd64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.17415_none_0b30df96304ee82e\sdiagnhost.exe
Expected: UNKNOWN Found: DVGVKuh3ceJlQR89WM5OPNKJSWnFWRLxqdUILyzqnA0=
Expected: 6.3.9600.17415 Found: Version number not available.
Successfully traced component amd64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.17415_none_0b30df96304ee82e.
Package_873_for_KB3000850~31bf3856ad364e35~amd64~~6.3.1.8.3000850-2600_neutral_GDR4
[1: 1] C:\Windows\WinSxS\wow64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.17415_none_158589e864afaa29\sdiagnhost.exe
Expected: UNKNOWN Found: XgtCaDuUIw2Ezid74EETbdSVZcc1lqOhRVIZnmJdxoY=
Successfully traced component wow64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.17415_none_158589e864afaa29.
Package_1610_for_KB3000850~31bf3856ad364e35~amd64~~6.3.1.8.3000850-4807_neutral_GDR4
[2: 2] C:\Windows\WinSxS\amd64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.20512_none_0bb7924b496f2252\sdiagnhost.exe
Expected: UNKNOWN Found: YorCyAvtQeot8Q359QhL15g0Rkgdp4Bs6RskoXVsKaw=
Expected: 6.3.9600.20512
Failed to trace component amd64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.20512_none_0bb7924b496f2252 with return code -1.
[C:\Windows\System32\sdiagnhost.exe]
[3: 2] C:\Windows\WinSxS\wow64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.20512_none_160c3c9d7dcfe44d\sdiagnhost.exe
Expected: UNKNOWN Found: UVhSfuwkWKxUBUlxkHRyzsopy4JXa/kOlxMTiHncM/w=
Failed to trace component wow64_microsoft-windows-s..csengine-nativehost_31bf3856ad364e35_6.3.9600.20512_none_160c3c9d7dcfe44d with return code -1.
[C:\Windows\SysWOW64\sdiagnhost.exe]
Currently storing 20 datablocks.
Finish time: 2022-09-30 18:17:58.288
Script hash: WmsdklPkWkc8pld34MsK0GqhpTKLFfHYYCjaido/J6k=
  4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog.
  6. Copy and paste KB5008263 into the Search box and click the Search Registry button.
Perform the instructions in message #31 again.
Ran the fix then restarted, just run sfcfix and SFCFix.txt is below, fixlog.txt is attached.
Start time: 2022-10-01 21:25:34.464
Using .txt script file at C:\Users\Admin\Desktop\SFCFixScript.txt [2]
FileScan::
Finish time: 2022-10-01 21:26:06.419
Do you still see the error about sdiagnhost.exe ?
Unfortunately popped up again. I've attached a couple of screenshots from event viewer
The faulting paths (from error_2) indicate the problem is at:
Faulting application path: C:\WINDOWS\System32\sdiagnhost.exe
Faulting module path: C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Manaa57fc8cc#\828e7a69baf5179fd3982bf8cfd68159\System.Management.Automation.ni.dll
