[SOLVED] [Win10v1607b14393 x64] 2017-05 Cumulative upd. fails; no problems detected by SFCFIX.
Here is the reply:
Start time: 2017-07-22 16:35:07.854
Microsoft Windows 10 Build 14393 - amd64
Using .txt script file at C:\Users\subodhan\Desktop\SFCScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\WOW6432Node\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\WOW6432Node\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\WOW6432Node\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Currently storing 25 datablocks.
Finish time: 2017-07-22 16:35:08.107
Script hash: 0Klk0uLV6yTc9P5cUPS7aOy+fyNdTxLDDx8JfDQshBc=
The command failed:
C:\WINDOWS\system32>DISM /Online /Get-Drivers
Version: 10.0.14393.0
Error: 3
An initialization error occurred.
Please find the DISM log below:
View attachment dism.zip
Please do the following.
2. Open an elevated Command Prompt and run DISM /Online /Get-Drivers just like you have in the past.
5. Zip up and attach the LogFile.PML file as well as your CBS.log and DISM.log
DISM /Online /Get-Drivers failed:
Error: 3
The zip file (dism.log, cbs.log and LogFile.pml) is available at:
https://1drv.ms/u/s!AmgYffdSBkYvmHE845KS8Kh9sZQp
It doesn't appear the capture was done correctly or it simply didn't work. You want to make sure Process Monitor is running BEFORE you open a command prompt and run the command DISM /Online /Get-Drivers. Then after the error happens go ahead and stop the capture and save the log. Could you try following the instructions again?
Thanks.
DISM failed:
Error: 3
The zip file is here:
https://1drv.ms/u/s!AmgYffdSBkYvmHLEci3HBKt3gmiv
Looks like my CBS log is not getting updated:
That is the time I executed the DISM in the morning
Got it. OK there are a couple things we can do here.
Step#1 - Add File
Please download this file and save it to your c:\windows\servicing\version\10.0.14393.0 folder. The file is named amd64_installed with no extension of any kind.
Step#2 - SFCFix Script
I cannot copy the amd64_installed file to the destination folder, since I do not have (write) access to the folder.
Also, if you could let me know how to fix the CBS log issue, that would be great.
OK, ignore the previous steps then. Only do the following. Don't worry about the CBS.log for the moment.
Start time: 2017-07-26 22:45:06.357
Using .zip script file at C:\Users\subodhan\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\Servicing\version\10.0.14393.0
Successfully copied file C:\Users\subodhan\AppData\Local\niemiro\Archive\amd64_installed to C:\WINDOWS\Servicing\version\10.0.14393.0\amd64_installed.
Successfully copied file C:\Users\subodhan\AppData\Local\niemiro\Archive\x86_installed to C:\WINDOWS\Servicing\version\10.0.14393.0\x86_installed.
Successfully restored ownership for C:\WINDOWS\Servicing\version\10.0.14393.0
Successfully restored permissions on C:\WINDOWS\Servicing\version\10.0.14393.0
Currently storing 26 datablocks.
Finish time: 2017-07-26 22:45:07.328
Script hash: fstTOowxFZ38NMvEwTExFIAdsrS/N6V4z1V+PD7EdDA=
Dism command failed:
Image Version: 10.0.14393.0
Error: 193
%1 is not a valid Win32 application.
The Dism and CBS logs are:
View attachment dism_cbs.zip
OK, please do the following.
2. Open an elevated Command Prompt and run Dism /Online /Cleanup-Image /RestoreHealth just like you have in the past.
Here is the result:
Error: 193
The zip file is below:
https://1drv.ms/u/s!AmgYffdSBkYvmHRHsEIaCTjoTXMy
OK, I have a few more ideas now after going through those logs. Please do the following.
Step#1 - SFCFix Script
