[SOLVED] [Win10v1607b14393 x64] 2017-05 Cumulative upd. fails; no problems detected by SFCFIX.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version
10.0.14393.82 REG_EXPAND_SZ %SystemRoot%\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.82_none_5be7b69702339d1d
Please do the following.
Step#1 - SFCFix Script
Start time: 2017-08-08 07:48:39.572
Microsoft Windows 10 Build 14393 - amd64
Using .txt script file at C:\Users\subodhan\Desktop\SFCScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_CLASSES_ROOT\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\WOW6432Node\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Successfully imported registry key HKEY_CLASSES_ROOT\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\WOW6432Node\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Successfully restored ownership and permissions for registry key HKEY_CLASSES_ROOT\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\WOW6432Node\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Currently storing 122 datablocks.
Finish time: 2017-08-08 07:48:40.146
Script hash: chhr8lEVYM/ibPNNAkTvS/iNht/xkX4NKUd64oD8lRc=
Version: 10.0.14393.0
Error: 1812
An initialization error occurred.
Dism and CBS log fles:
View attachment dism_cbs_LogFile.zip
Can you try the following one more time?
1. Download the Media Creation Tool and save this to your desktop. Go ahead and run this as well. Note: Click the Download tool now button when you get to this link.
2. Accept the License Agreement
3. Keep the default Upgrade this PC option and click Next.
4. Let this process complete the upgrade to the newest build and let me know when complete.
The Media Creation Tool link is broken.
I have taken the address from the link and started the download and install process. Will update with the results.
Do you have any complete backups of this machine? Since your components hive is corrupted beyond repair I'm wondering if there is an uncorrupt version laying around on an old backup?
Also, do you know how far back your restore points go on your computer? Do you know how to check?
I may have a system back up, however it may be couple years old. It was taken almost immediately after moving from Win 8 to Win 10.
There seem to be only 4 restore points: from 12/12/2016, 7/21/2017. 7/28/2017 and 8/6/2017.
I can get a new disk and load the new windows 10 upgrade on that disk. However, I will need to install all my software all over again. Also there will the issue of migrating my license key to the new install.
Please navigate to the following path.
C:\windows\system32\config
Right-click on the COMPONENTS file and select properties. Then choose the Previous Versions tab. Let me know if any dates come up?
There are no previous versions available.
There are multiple files in the same folder that start with COMPONETS:
The 12/12/2016 is a Windows Image Backup and cannot be traversed down.
I can reach the file in 7/21/2017 restore point though.
I have copied the file out on the desktop. It is a very small file (8KB) as compared to the existing one(9472 KB)
