[SOLVED] [Win10v1607b14393 x64] 2017-05 Cumulative upd. fails; no problems detected by SFCFIX.
Start time: 2017-08-07 18:44:50.363
Microsoft Windows 10 Build 14393 - amd64
Using .txt script file at C:\Users\subodhan\Desktop\SFCScript.txt [0]
FileScan::
[0: 1] C:\Windows\System32\config\COMPONENTS
File is untraceable.
Found: 9U0CBO9r9apkuL1k3yMfPEeCS2tt55cveHP1US6kAlM=
Version number not available.
Trace not available.
Currently storing 122 datablocks.
Finish time: 2017-08-07 18:45:04.982
Script hash: PyP7WgzjGIZu3/sbtZOz+9VNef5bwnZ+5x+nfACwBq4=
Please do the following.
Step#1 - SFCFix Script
Start time: 2017-08-07 18:58:48.344
Using .txt script file at C:\Users\subodhan\Desktop\fixlist.txt [0]
Finish time: 2017-08-07 18:58:48.360
Script hash: WOk1xlA5GB77/ibbnHTh6PBlimbucbIy+MU1fWWBw/w=
FRST Fix
DISM run:
Version: 10.0.14393.0
Error: 1812
An initialization error occurred.
dism and cbs logs:
View attachment dism_cbs_logFile.zip
Good. Open an elevated command-prompt and paste the following into it and hit enter.
reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version" /s >1.txt && notepad 1.txt
Notepad will open showing the contents of this key. Can you copy and paste this into your next reply?
10.0.14393.0 REG_EXPAND_SZ %SystemRoot%\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.14393.0_none_36d3ccc3ddfd1ecb
FRST Fix
Fix result of Farbar Recovery Scan Tool (x64) Version: 06-08-2017
Ran by subodhan (07-08-2017 22:07:44) Run:5
Running from C:\Users\subodhan\Desktop
Loaded Profiles: subodhan (Available Profiles: subodhan & .NET v4.5 & DefaultAppPool & .NET v4.5 Classic)
Boot Mode: Normal
fixlist content:
StartRegEdit:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version]
"10.0.14393.82"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6D,00,\
52,00,6F,00,6F,00,74,00,25,00,5C,00,77,00,69,00,6E,00,73,00,78,00,73,00,\
5C,00,61,00,6D,00,64,00,36,00,34,00,5F,00,6D,00,69,00,63,00,72,00,6F,00,\
73,00,6F,00,66,00,74,00,2D,00,77,00,69,00,6E,00,64,00,6F,00,77,00,73,00,\
2D,00,73,00,65,00,72,00,76,00,69,00,63,00,69,00,6E,00,67,00,73,00,74,00,\
61,00,63,00,6B,00,5F,00,33,00,31,00,62,00,66,00,33,00,38,00,35,00,36,00,\
61,00,64,00,33,00,36,00,34,00,65,00,33,00,35,00,5F,00,31,00,30,00,2E,00,\
30,00,2E,00,31,00,34,00,33,00,39,00,33,00,2E,00,38,00,32,00,5F,00,6E,00,\
6F,00,6E,00,65,00,5F,00,35,00,62,00,65,00,37,00,62,00,36,00,39,00,37,00,\
30,00,32,00,33,00,33,00,39,00,64,00,31,00,64,00,00,00
"10.0.14393.0"=-
EndRegEdit:
====> Registry
==== End of Fixlog 22:07:44 ====
So the script is failing to do its intended function. Please try the following.
Start time: 2017-08-07 22:19:21.059
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version.
Finish time: 2017-08-07 22:19:21.274
Script hash: RSjmYo2YnyuyxxrZ5KTayehaSp+aM+w9LZznFiLfpqo=
