[SOLVED] [Win10v1607b14393 x64] 2017-05 Cumulative upd. fails; no problems detected by SFCFIX.
Please do the following.
Step#1 - SFCFix Script
Here is the reply:
Start time: 2017-08-05 16:36:22.172
Microsoft Windows 10 Build 14393 - amd64
Using .txt script file at C:\Users\subodhan\Desktop\SFCScript.txt [0]
FileScan::
[0: 2] C:\Windows\servicing\TrustedInstaller.exe
File is untraceable.
Found: SD/lWHOgHbes7Jm2gj2qzJ6nxn02xvEmmBE7MafVuL4=
Found: 10.0.14393.0
Trace not available.
[C:\Windows\WinSxS\amd64_microsoft-windows-trustedinstaller_31bf3856ad364e35_10.0.14393.0_none_be819eff63d95a62\TrustedInstaller.exe]
Currently storing 26 datablocks.
Finish time: 2017-08-05 16:36:24.883
Script hash: +Qv4gzT7f2dklNoMdnvNcngAsxIJr4RLRI1NzQG6WPg=
That was unexpected. Please do the following.
FRST Fix
FRST64 response:
Fix result of Farbar Recovery Scan Tool (x64) Version: 06-08-2017
Ran by subodhan (06-08-2017 18:58:03) Run:2
Running from C:\Users\subodhan\Desktop
Loaded Profiles: subodhan (Available Profiles: subodhan & .NET v4.5 & DefaultAppPool & .NET v4.5 Classic)
Boot Mode: Normal
fixlist content:
c:\windows\system32\downlevel
c:\windows\system32\downlevel => moved successfully
==== End of Fixlog 18:58:03 ====
Interesting. Can you extract the contents of the zip file to a folder on your desktop? we need to copy the contents of the downlevel folder in the zip to your c:\windows\system32\downlevel folder which is currently empty.
Are you familar enough with windows to do this on your own?
Version: 10.0.14393.0
Image Version: 10.0.14393.0
Error: 193
%1 is not a valid Win32 application.
CBS.zip is here:
View attachment cbs.zip
FRST Fix
Fixlist.txt:
Ran by subodhan (06-08-2017 22:27:17) Run:3
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
StartRegEdit:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version]
"10.0.14393.82"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6D,00,\
52,00,6F,00,6F,00,74,00,25,00,5C,00,77,00,69,00,6E,00,73,00,78,00,73,00,\
5C,00,61,00,6D,00,64,00,36,00,34,00,5F,00,6D,00,69,00,63,00,72,00,6F,00,\
73,00,6F,00,66,00,74,00,2D,00,77,00,69,00,6E,00,64,00,6F,00,77,00,73,00,\
2D,00,73,00,65,00,72,00,76,00,69,00,63,00,69,00,6E,00,67,00,73,00,74,00,\
61,00,63,00,6B,00,5F,00,33,00,31,00,62,00,66,00,33,00,38,00,35,00,36,00,\
61,00,64,00,33,00,36,00,34,00,65,00,33,00,35,00,5F,00,31,00,30,00,2E,00,\
30,00,2E,00,31,00,34,00,33,00,39,00,33,00,2E,00,38,00,32,00,5F,00,6E,00,\
6F,00,6E,00,65,00,5F,00,35,00,62,00,65,00,37,00,62,00,36,00,39,00,37,00,\
30,00,32,00,33,00,33,00,39,00,64,00,31,00,64,00,00,00
"10.0.14393.0"=-
[HKEY_CLASSES_ROOT\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6D,00,\
30,00,32,00,33,00,33,00,39,00,64,00,31,00,64,00,5C,00,54,00,69,00,57,00,\
6F,00,72,00,6B,00,65,00,72,00,2E,00,65,00,78,00,65,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\WOW6432Node\CLSID\{0823B6F8-F499-4d5e-B885-EA9CB4F43B24}\LocalServer32]
5C,00,78,00,38,00,36,00,5F,00,6D,00,69,00,63,00,72,00,6F,00,73,00,6F,00,\
66,00,74,00,2D,00,77,00,69,00,6E,00,64,00,6F,00,77,00,73,00,2D,00,73,00,\
65,00,72,00,76,00,69,00,63,00,69,00,6E,00,67,00,73,00,74,00,61,00,63,00,\
6B,00,5F,00,33,00,31,00,62,00,66,00,33,00,38,00,35,00,36,00,61,00,64,00,\
33,00,36,00,34,00,65,00,33,00,35,00,5F,00,31,00,30,00,2E,00,30,00,2E,00,\
31,00,34,00,33,00,39,00,33,00,2E,00,38,00,32,00,5F,00,6E,00,6F,00,6E,00,\
65,00,5F,00,66,00,66,00,63,00,39,00,31,00,62,00,31,00,33,00,34,00,39,00,\
64,00,36,00,32,00,62,00,65,00,37,00,5C,00,54,00,69,00,57,00,6F,00,72,00,\
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Component Based Servicing\Version]
"10.0.14393.0"=-
RestoreQuarantine: C:\FRST\Quarantine\C\Windows\servicing\version\10.0.14393.82
C:\Windows\servicing\version\10.0.14393.0
EndRegEdit
====> Registry
==== End of Fixlog 22:27:57 ====
Error: 193
cbs.zip is here:
OK, I need to see updated hives. Please do the following.
Retrieve Components/Software Hives
Note: The Software have has confidential and sensitive information in it so please send me a PM with a link to that particular hive so it's not in the public form.
  • This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, two of which are named COMPONENTS and SOFTWARE.
  • Copy these two files to your Desktop. If the COMPONENTS file does not exist, please fetch it instead from C:\Windows\System32\config\COMPONENTS.
  • Now right click on these files on your desktop and select Send to > Compressed (zipped) folder.
  • Then please upload the zip file(s) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Dropbox or One Drive or SendSpace and then just provide the link in your reply.
