[SOLVED] Windows 7 Ultimate 64bit - Control Panel: Phone and Modem CP corrupted
I have far too many legacy programs on this machine. I want to fix it so I can virtualize it and run it under VMware workstation on the same host running win10. That's the plan anyway. Never had any good outcome upgrading win7 to win10 on other PCs. Outright installs are always better IMHO.
Okay.
Some more info:
Step#1 - FRST Fix
Thank you. Could you please navigate to the following registry key and take a screenshot?
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Telephony\Country List\995
Thank you!
Step#1 - FRST Fix
Step#1 - FRST Fix
