[SOLVED] [WinServer2012] Standard WSUS Problems
"Update for Windows (KB3172615) is already installed on this computer."
-Pyro
"Update for Windows (KB3205409) is already installed on this computer."
-Pyro
I turned the WSUS service back on and told it to install updates as needed. Rebooted once again, and it's checking for updates now. I'll let it run over night and update you tomorrow, thanks a bunch for all the help so far Brian!!
-Pyro
Nothing, 19 hours later and still sitting at "Checking for updates..." Most recent check for updates: Never Updates were installed: Never You receive updates for: Windows only.
-Pyro
Thank you. I need to gather some more info. Please do the following.
1. Point your mouse to the lower left corner of your screen and hover there until the Start Screen icon appears. Then move your mouse on to the Start Screen and right-click and choose Command Prompt (Admin).
2. A User Account Control dialog may come up asking for approval. If it does go ahead and allow.
3. A command prompt window will open. Copy/Paste the following into the command-prompt and hit enter.
wmic qfe list brief /format:texttablewsys > "%USERPROFILE%\desktop\hotfix.txt"
4. After the command runs there will be a file on your desktop named hotfix.txt.
5. Please zip/attach this file.
Thank you.
Thanks. Need some more info.
reg query HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate /s >1.txt && notepad 1.txt
4. Notepad will open showing the WU info. Can you copy and paste this into your next reply?
Absolutely:
SusClientIdValidation REG_BINARY 06021C0100205000360031003600330030004B00390053005700340037003700500006A44A4D6A478F5500530045003800320037004E00360031003900200020002000200020002000
SusClientId REG_SZ 2f5d4cf7-fe2e-42a0-8ea1-2af51464058a
ResetClient REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update
AUOptions REG_DWORD 0x4
IncludeRecommendedUpdates REG_DWORD 0x1
ElevateNonAdmins REG_DWORD 0x1
NonFirmwareUpdatesAvailableForInstall REG_DWORD 0x0
NextDetectionTime REG_SZ 2017-03-02 04:25:09
CachedAUOptions REG_DWORD 0x4
InstallInProgress REG_DWORD 0x0
UpdatesAvailableForDownloadLogon REG_DWORD 0x0
UpdatesAvailableForInstallLogon REG_DWORD 0x0
UpdatesAvailableWithUiOrEulaLogon REG_DWORD 0x0
UpdatesAvailableWithUiLogon REG_DWORD 0x0
FirmwareUpdatesNotDownloaded REG_DWORD 0x0
FirmwareUpdatesNotInstalled REG_DWORD 0x0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Power
Firmware-Final REG_DWORD 0x1e
OfferInstallAtShutdown-Final REG_DWORD 0x28
ContinueInstallAtShutdown-Final REG_DWORD 0xa
FirmwareForcedInstall-Final REG_DWORD 0x23
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\RequestedAppCategories
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\RequestedAppCategories\117cab2d-82b1-4b5a-a08c-4d62dbee7782
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\RequestedAppCategories\9482f4b4-e343-43b6-b170-9a65bc822c77
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\UAS
UpdateCount REG_DWORD 0x0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Reporting
SamplingValue2 REG_DWORD 0x296
BatchFlushAge REG_DWORD 0x5633
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Reporting\EventCache.v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Reporting\EventCache.v2\Legacy
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Reporting\RebootWatch
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Services
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Services\117cab2d-82b1-4b5a-a08c-4d62dbee7782
AuthCabRefresh REG_SZ 2017-03-01 23:39:52
AuthorizationCab REG_SZ 117cab2d-82b1-4b5a-a08c-4d62dbee7782.cab
RegisteredWithAU REG_DWORD 0x1
RedirRefresh REG_SZ 2017-03-01 00:36:59
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Services\9482f4b4-e343-43b6-b170-9a65bc822c77
RedirRefresh REG_SZ 2017-03-02 04:25:34
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Services\Pending
ValidatedPreWsus3RegistrationRequests REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Setup
SelfUpdateStatus REG_DWORD 0x0
SelfupdateUnmanaged REG_DWORD 0x1
ServerId REG_SZ 9482f4b4-e343-43b6-b170-9a65bc822c77
SetupHandlerUpdateId REG_SZ 61ca813a-7585-442e-a66b-b0d15ce6bdc0
UpdateSessionId REG_DWORD 0xffffffff
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Setup\Results
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Setup\Results\SelfUpdate
LastSuccessTime REG_SZ 2014-08-23 00:04:41
RebootFailCount REG_DWORD 0x0
LastError REG_DWORD 0x0
-Pyro
Step#1 - SFCFix Script
Here you go:
Start time: 2017-03-03 21:25:50.260
Microsoft Windows Server 2012 - amd64
Using .txt script file at C:\Users\Administrator\Desktop\SFCScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Detect.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Download.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Detect.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Download.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install.
Finish time: 2017-03-03 21:25:50.590
Script hash: trRmPhYzDe17YqvwbZiQk3wwxZPzBqDGeQVKZI9Uftw=
-Pyro
Reboot and then attempt to check for Windows Updates again. Let me know the results. If it goes beyond two hours then it's likely not going to work. Just let me know.
Sorry, tried to time it last night but ended up falling asleep... Still checking for updates as of 10:16 this morning.
-Pyro
Make sure your Windows Update setting is still set to Never "check for updates". Let's try installing some more updates. This one is really interesting.
Manually download and attempt to install the following update.
KB2771431
