[SOLVED] [WinServer2012] Standard WSUS Problems
KB3118401 - Installed Successfully
KB3121255 - Installed Successfully (Prompted for a reboot)
KB3123242 - Installed Successfully (Prompted for a reboot)
KB3125424 - Installed Successfully (Prompted for a reboot)
KB3134242 - Installed Successfully (Prompted for a reboot)
5/5, pretty excited of our progress so far! Haven't restarted the server yet.
-Pyro
OK, restart and then check for updates and let me know if it finds any. I'm off to a soccer game for an hour or so and will be back with next steps.
Still sitting at the "Checking for updates..." screen for about 2 hours now.
-Pyro
OK, let's reboot your machine and then check for updates again. Let's see if it finishes checking.
Also, do you have any other Server 2012 machines that are functioning fine?
Ok, rebooting now. No, this is the only 2012 standard we have. All the others are R2 and they aren't giving us any problems.
-Pyro
Thanks. If you could also provide a screen shot of your Windows Update screen on the server. It should look similar to the following.
Lastly, assuming that when you check for updates nothing shows up after 20 minutes please do the following.
Step#1 - Run Windows Repairs
1. Download Windows Repair (All-in-One) Portable to your desktop.
2. Once the file is downloaded, right-click on the file on your desktop and choose Extract All...
3. Keep the defaults and click the Extract button.
4. A folder named tweaking.com_windows_repair_aio will be extracted to the desktop. Once the extraction is complete the folder will open.
5. Inside this folder, there is a folder named Tweaking.com - Windows Repair. Open this folder as well.
6. Double-click on Repair_Windows.exe to open.
7. When the program opens, click the Repairs tab and click the Open Repairs button.
8. A backup of your registry will be made. After a few moments you will have many options from which you can choose.
9. Please click the Unselect All button and then click to enable only the following ones:
05 - Repair WMI
14 - Remove Temp Files
15 - Repair Proxy Settings
17 - Repair Windows Updates
21 - Repair MSI (Windows Installer)
10. Ensure the Restart check box is selected and click the Start Repairs button in the lower right of the screen. This may take some time to run so be patient.
11. Once the fixes are complete you will be prompted to restart your machine. Answer Yes.
Absolutely. Attached screenshot.
-Pyro
All set. I ran the tool with the following enabled:
05 - Repair WMI
I did NOT however get prompted to restart, it just did it on it's own. It didn't spit out a log file either (Or I just can't find it?) I'm attempting to check for updates once again. I'll let you know how I turn out.
-Pyro
Please do the following on any other server that you have. Don't worry about what OS it is.
Step#1 - Export WU Info
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\
  5. Change the Save as type: to Registry Hive Files (*.*)
  6. Name this file WU (with no file extension) and save it to your Desktop.
  7. Please zip and attach this file.
There you go. That export came from a Server 2008 Standard (Vista) machine with no problems.
-Pyro
