[SOLVED] [WinServer2012] Standard WSUS Problems
While I review this, can you disable IPv6 on your network adapter that connects this machine to the LAN?
You can do this by unbinding the adapter in the Local Area Connection Properties dialog box:
  • Click Start, and then click Control Panel.
  • Click Network and Sharing Center.
  • In the View your active networks area, click Local Area Connection, and then click Properties.
  • On the Networking tab, clear the Internet Protocol Version 6 (TCP/IPv6) check box, and then click OK.
Once this is done, check for updates and see if it works.
Please also do this for the server having issues.
Step#1 - Export WU Info
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\
  5. Change the Save as type: to Registry Hive Files (*.*)
  6. Name this file WU (with no file extension) and save it to your Desktop.
  7. Please zip and attach this file.
There is the 2nd registry export. I named it WU2012.zip for comparative purposes. I attempted to restart the Windows Update services after the change I made to the IPv6 setting, but it would not restart and it's stuck at a "Stopping" state. I'll reboot and try checking again. I'll keep you posted.
-Pyro
Just an update, rebooted just fine, IPv6 is currently disabled, and I'm currently checking for updates now.
-Pyro
If nothing is found after 30 minutes, please re-enable IPv6, run the following script and then reboot and check for updates again.
Step#1 - SFCFix Script
Here is the log file it gave me:
SFCFix version 3.0.0.0 by niemiro.Start time: 2017-03-06 20:03:51.974
Microsoft Windows Server 2012 - amd64
Using .txt script file at C:\Users\Administrator\Desktop\SFCScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate.
Successfully deleted registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate.
Successfully deleted registry key HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate.
Failed to open registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate with error code ERROR_FILE_NOT_FOUND.
Failed to open registry key HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate with error code ERROR_FILE_NOT_FOUND.
RegistryScript:: directive failed to complete successfully.
Finish time: 2017-03-06 20:03:52.239
Script hash: QRmanKCgxKu2y86uf2esqoexBVmkrbPpeiuJ/1Hs6qI=
-Pyro
Rebooted my machine and now I see "Turn on automatic updating" when I open up Windows Update, I haven't touched anything yet. Uploaded a screenshot.
-Pyro
Nothing... Looked promising, but still sitting at the "Checking for updates..." screen for over an hour now...
-Pyro
Nothing... Both cores are sitting idle at 1-2%. Intel Xeon 3060 2.4 GHz btw so one of them is a virtual socket.
-Pyro
Thanks again for all your help Brian. I'll check back with you tomorrow evening and let you know what happens.
-Pyro
2 NICs, one of them is being utilized. Uploaded screenshot.
-Pyro
Actually, correction on my last statement, there's one network card in the server, it has two ports on it, currently plugged into the one on the right.
-Pyro
Thanks for the info. Can you please zip up all the files in the following directory and send me a PM with the link to download the file?
C:\windows\system32\winevt\logs
