[SOLVED] 0xc1900101 - 0x30018 installation failed at FIRST_BOOT phase with a error during SYSPREP_SPECIALIZE
1. Download SPTD for Windows 10 (64 bit) to your desktop.
  • Right-click SPTD2inst-v213-x64.exe and select "Run as administrator".
  • Click on the Uninstall button. If it is grayed out, SPTD is not present in your system.
  • Restart the computer after removal/uninstalling SPTD.
2. Download AVG Clear to your desktop.
  • Right-click avgclear.exe and select "Run as administrator".
  • Now you see the message: It is recommended to run this tool from Windows Safe Mode. Do you want to do that?
  • Click Yes and run this tool from there.
  • Follow the instructions and restart the computer in normal mode.
3. Check if Minidump logging is enabled.
  • Open Control Panel > System and Security > System.
  • Click in the right panel on Advanced System Settings and a new window (System Poperties) will open.
  • In the Start-up and Recovery section click on Settings.
  • In the System Failure > Write Debugging Information section > Select the option Automatic memory dump.
  • Click on OK and Apply and restart the computer.
4. Run Windows Update again, If you get a BSOD perform the instructions in #post 39.
Check if the following logfiles are present:
C:\$Windows.~BT\Sources\Rollback\Setupact.log
C:\$Windows.~BT\Sources\Rollback\Setuperr.log
C:\$Windows.~BT\Sources\Rollback\setupapi\setupapi.dev.log
If so please attach them to your next reply.
Click the Start button and in the search box, type Command Prompt
When you see Command Prompt on the list, right-click on it and select Run as administrator.
When command prompt opens, copy and paste the following commands into it, press enter after each.
Take a screenshot of the commandprompt window and paste it into your next reply.
Run Windows Update again, if it fails attach a new copy of the CBS folder to your next reply.
Here you go failed in the same way with BSOD
I have never been able to install Feature update to Windows 10, version 1903 or Feature update to Windows 10, version 20H2 (2) successfully they have failed and rolled back many many times.
thank you and happy new year
Happy New Year to you.
This version of Windows 10 - 1803 - has not received any updates since November 2019. That is why it is a difficult problem to fix, but I do not give up so easily!
Please, attach a copy of the components HIVE to look further into this issue..
Start the
  • Press the Fix button.
Start the
Thanks I ran the new fixlist and attached the log.
Windows update then ran and it failed in the same way I attached the CBS
Download and run SetupDiag from Microsoft
  • Download
    SetupDiag to your desktop.
  • Right-click on SetupDiag.exe and select Run as administrator.
  • When completed the following files are created: "Logs.zip, SetupDiag.exe.config and SetupDiagResults.log"
  • Attach SetupDiagResults.log and Logs.zip to your next reply.
Please zip and attach the following memory dump file if present.
C:\$WINDOWS.~BT\Sources\Rollback\setupmem.dmp
The memory dump file has signs of a problem with the driver of the Mellanox ConnectX-3 Ethernet Adapter. Lets first try to update the network driver.
Download and install this driver. After installing the driver, please reboot the computer and then try Windows Update again and let me know the result.
