[SOLVED] 0xc1900101 - 0x30018 installation failed at FIRST_BOOT phase with a error during SYSPREP_SPECIALIZE
That driver would not run it said it was for windows 19
I also though the issue was with the Mellanox driver I tried removing the card before windows update many months ago but still got a BSOD.
Did you also uninstall all the software and drivers of Mellanox after removing the networkcard?
Step 1. Remove the networkcard again and uninstall the following Mellanox software.
- MLNX_VPI
- WinMFT64
Step 2. Start the
  • Note: Your antivirus program may report FRST incorrectly as an infection. If so, disable the real-time protection when downloading and running FRST.
  • Right-click to run the tool as administrator. When the tool opens click Yes to disclaimer.
  • Note: Ensure that the Addition.txt check box is checked at the bottom of the form within the Optional Scan area.
  • Press the Scan button.
  • Please wait for the tool to finish. It will produce two logfiles called FRST.txt and Addition.txt in the same directory the tool is run from (which should be the desktop)
  • Post the logfiles FRST.txt and Addition.txt as attachment in your next reply.
I removed the network card but when I ran the uninstall for MLNX_VPI and WinMFT64 it said only "action only valid for products that are currently installed"
I ran frst and attached teh files for you
Sorry, my bad! Insert the network card back into the system, and follow the instructions #64 again and remove the network card after step 1.
I reinstalled the card but the uninstall would still not run for those 2. they were not in uninstall programs but under the mellanox folder. The best I could do in remove the card in device manager and uninstall the driver.
Please, remove the network card again. Run FRST with the scan function again and attach both logs FRST.txt and Addition.txt
Step 1. Remove the Mellanox System Variables.
  • Click the Start button and in the search box, type sysdm.cpl
  • When you see sysdm.cpl > Control Panel Item on the list, right-click on it and select Run as administrator.
  • Open the tab Advanced and click on Environment Variables.
  • Select in the System variables section > Path and click on the Edit button.
  • Select the following entry's and click on the Delete button.
    • C:\Program Files\Mellanox\MLNX_VPI\IB\Tools
    • C:\Program Files\Mellanox\MLNX_WinOF2\Management Tools
    • C:\Program Files\Mellanox\MLNX_WinOF2\Performance Tools
    • C:\Program Files\Mellanox\MLNX_WinOF2\Diagnostic Tools
    • C:\Program Files\Mellanox\\WinMFT
    • C:\Program Files\Mellanox\MLNX_CIMProvider\lib\mft
  • Click on Ok and close the System Properties window.
Step 2 Start the
  • Press the Fix button.
Run Windows Update again, if it fails attach a new copy of the CBS folder to your next reply.
Please, disconnect all peripheral (USB and other) devices that are connected to the system, except for the mouse, keyboard and display.
Run Windows Update again, if it fails attach the following files to your next post.
C:\$WINDOWS.~BT\Sources\Rollback\setupmem.dmp
C:\$WINDOWS.~BT\Sources\Rollback\setupapi\setupapi.dev.log
it failed again
there was no C:\$WINDOWS.~BT\Sources\Rollback\setupmem.dmp
I did find a setupmem.dmp in the C:\WINDOWS\Panther\NewOs\Rollback folder From 1/4 here is a link to that setupmem.zip
I attached C:\$WINDOWS.~BT\Sources\Rollback\setupapi\setupapi.dev.log
Thank You
Please attach also a new copy of the CBS.log.
Open an elevated command prompt.
Copy and paste the following command into it, then press enter.
This command will create cbs.txt on your Desktop. Zip this file and attach the zipped cbs.txt to your next post.
Please download this LAN-driver for your motherboard and install it.
Restart the computer, try Windows Update again and let me know the result.
I updated the LAN driver and ran windows update it failed with the same BSOD.
Attach the following logfiles to your next post.
C:\$WINDOWS.~BT\Sources\Rollback\Setupact.log
C:\$WINDOWS.~BT\Sources\Panther\Setupact.log
