[SOLVED] Problem!!!
  • Once done, a file will appear on your desktop, called SFCFix.txt
Next ...
  • Restart the computer.
  • Run the command SFC /SCANNOW in an elevated command prompt and report the result.
  • If it fails, attach a zipped C:\Windows\Logs\CBS\CBS.log to your next reply.
Good Afternoon Gary,
Thanks for the latest SFCFix.zip, which I have applied (please see attached SFCFix.txt). Following a reboot, the SFC /scannow command has now reached 72% before failing again:
Microsoft Windows [Version 10.0.19043.1526]
(c) Microsoft Corporation. All rights reserved.
Verification 72% complete.
Windows Resource Protection could not perform the requested operation.
Please find attached a zip of the latest CBS.log file.
Thanks for all your help.
Next ...
Hi Gary,
Thanks for your latest SFCFix.zip, which I have applied (please see output SFCFix.txt). Following a restart, the SFC /scannow command has reached 74% complete, before failing again:
Verification 74% complete.
Please find attached a zip of the latest CBS.log file (CBS.zip).
Thanks for your help.
Still creeping up then. ;)
Looking over the logs, back ASAP.
Next ...
Good Morning Gary,
Thank you for the latest SFCFix.zip update, which I have applied (please see attached SFCFix.txt). After a restart, the SFC /scannow command reached 75% before failing again:
Verification 75% complete.
Please find attached the latest CBS.log zip file.
Looking over your latest logs now.
Got a lot on today, so depending on how things go, I may not get back to you till tomorrow at the earliest.
And a Happy Easter to you as well. Jobs got done quicker than I'd anticipated, so I got a bit of spare time, and there was only one file to source in your latest logs, so ....
Next ...
Good afternoon Gary,
Thanks for your kind greetings and the new update. I have applied the latest SFCFix.zip (please see attached SFCFix.txt). After a restart, the SFC /scannow command reached 78% before failing:
Verification 78% complete.
Please find attached the latest CBS.log file (CBS.zip).
Next ...
Good Morning Gary,
Thank you for the latest SFCFix.zip update, which I have applied (please see attached SFCFix.txt). Following a restart, the SFC /scannow command reached 83% complete before failing again:
Verification 83% complete.
Please find attached a zip of the CBS.log file.
Thanks for your help and support.
Sorry for the delay. Things got a bit busy over Easter.
Next ...
Good Morning Gary,
Thanks for your update. Not to worry - it's the Easter Holiday!
I shall apply your latest fix now and let you know the result ...
Hi Gary,
I have applied the latest SFCFix.zip (please see attached SFCFix.txt). Post reboot, the SFC /scannow command now reaches verification 88% complete before failing again:
Verification 88% complete.
Thanks for all your help and support.
Getting closer. ;)
Looking over the latest logs now, back ASAP.
Next ...
