- Aug 13, 2021
- 3,348
Next ...
- Download the attachment SFCFix.zip and save it on your desktop.
- Save any work you have open, and close all programs.
- Drag the SFCFix.zip file over the SFCFix.exe executable and release it.
- SFCFix will launch, let it complete.
- Once done, a file will appear on your desktop, called SFCFix.txt
- Open the file, then copy and paste its content in your next reply.
Next ...
- Restart the computer.
- Run the command SFC /SCANNOW in an elevated command prompt and report the result.
- If it fails, attach a zipped C:\Windows\Logs\CBS\CBS.log to your next reply.
