[Win8/8.1] GUIDE: CNBJ2530.DPB and prncacla.inf Corruptions
Re: GUIDE: CNBJ2530.DPB and prncacla.inf Corruptions - Windows 8/8.1
Hi Tekno! my apps crushing after windows 8.1 update
\WinSxS\amd64_prncacla.inf_31bf3856ad364e35_6.2.9200.16430_none_fdce12188b615b12\Amd64\CNBJ2530.DPB %UserProfile%\Desktop\Tekno_Venus\Amd64\CNBJ2530.DPB
what the next step?
Where did you get the contents of that code box from? That's not in the tutorial anywhere?
Try fixing it with DISM - as described in Method 1. If DISM fails, then Method 2 is for you. Let me know if you have any problems with them.
Stephen
Hi Stephen, I just follow up that post:
  2. Download the file below, SFCFix.txt, and save this to your Desktop.
  4. On your Desktop, you should see two files: SFCFix.exe and SFCFix.txt.
  5. Drag the file SFCFix.txt onto the file SFCFix.exe and release it.
  7. Upon completion, a file and a folder should be created on your Desktop, titled SFCFix.txt and Tekno_Venus respectively.
  8. Copy (Ctrl + C) and Paste (Ctrl + V) the contents of the SFCFix.txt file into your next post for me to analyse please - put
Those instructions are different to the ones in the tutorial. You no longer need to create a Tekno_Venus folder on your desktop. :)
Follow the instructions in the first post of the tutorial --> https://www.sysnative.com/forums/wi...nf-corruptions-windows-8-8-1-a.html#post59076.
Stephen
Hey,
Did anyone else notice that the DISM command changes the SYSTEM security settings of the file CNBJ2530.DBP seen in its Properties box? Unlike all the other DPB files in the same folder, this file doesn't seem to let SYSTEM have full access to it anymore (only "read" and "execute" are checked). I'm not sure this could lead to any potential problems later on... (see pictures below)
Thank you for that very useful information.
I do not see that causing any issues, but again, thanks for posting that! That could come in very handy to know!
Stephen
Stephen
Don't mention it, glad I could inform. ;)
The potential problems I was thinking about are problems such as when a future update (i.e. windows 8.2?) comes out for which files are needed to be modified, renewed, etc. by SYSTEM. Not sure if the developers are aware of DISM doing this. Then again, I could be wrong...
Stephen
It does not look like it will cause further issues to me. The SYSTEM account is only used for future updates under impersonation if the permissions for the TrustedInstaller account have been messed up (that's what Windows Update will use by preference). I can reset the permissions on that file if you like, but I don't think it's needed. Second question: what is the current owner on that file (Properties > Security tab > Advanced > Owner tab)? If it's not TrustedInstaller, then I would consider acting, although again I don't think it will be needed due to impersonation (but I might still act here).
Thank you.
Richard
Stephen
Thank you.
Richard
Thanks for your info and help. If I understand correctly, the SYSTEM only needs these full permissions in case the TrustedInstaller account priviliges are not enough or messed up? It says indeed that the Owner of the file is TrustedInstaller so I guess I shouldn't worry.
Hi guys.
Tekno Venus your gui for me it's all ok with Niemiro tools.
But there is just a strange thing because after having the procedure done successful, after a reboot of the PC comes back again the same error and I have to redo the steps in the guide?? :eek::eek::eek4: Waiting for an answer I greet all.
T.T Admin or any1 here pls help me. I have sucessfully repair it and run scfc/scannow to test it and no problem.Then,i restart pc and test again sfc/scannow and the problem occur again~~ pls help T.T
For those experiencing the issue where the file is reported corrupt again after a reboot, please attempt the fix again - starting first with DISM.
If it still continues after another reboot, do not worry. In all honestly, this is a minor corruption and shouldn't affect the day to day running of your computer. If you have indeed performed the replacement and fixed it once, then it may be SFC falsely reporting the error. Do not worry about it, it's not a concerning corruption and shouldn't cause any problems.
Stephen
Stephen
While I agree this doesn't really need to be fixed as it will only be experienced by few people, I still think that it's best to fix this so that any future detections by SFC aren't ignored and passed off as this issue when they could be other corruptions. I know all it takes to determine this is looking at the CBS log, but it isn't half overwhelming at first :p
Background, Acer Aspire, T3-605. It came with Acer installed W8 and has been upgraded by me to W8.1 (not a fresh install). It has been running trouble free until recently, a failed Windows Update KB2919355 with error 80073712 got my attention.
So far, I have tried MS Online scan (no virus were found). chkdsk /r and chkdsk /scan and also /spotfix Didn't see any errors. Windows defender has been on the whole time. No virus scanners installed.
I've been looking at this issue for about a week now. It started with 2919355 will not update automatically nor manually. Then I tracked down through DISM (error 0x80240021) and sfc; those reported errors, but unable to fix those corruptions.
SFC showed this...
00000590 [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
2014-04-19 10:04:42, Info CSI 00000591 Hashes for file member \SystemRoot\WinSxS\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.16384_none_9590ba64d5b91f79\Amd64\CNBJ2530.DPB do not match actual file [l:36{18}]"Amd64\CNBJ2530.DPB" :
I then followed your guide and stuck in Method 1.
SFCfix.exe were ran in both in normally loaded W8.1 and clean state W8.1 No changes when I ran DISM/sfc afterward, both still reported errors and can't fix.
My question is: Once those corrupted files are restored, would I be able to install 2919355? Thanks!
SFCFix version 2.2.1.0 by niemiro.
Start time: 2014-04-20 22:13:51.990
FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.16384.
CBS & SFC total fixed corruption count: 1
SFCFix version 2.2.1.0 by niemiro has completed.
Finish time: 2014-04-20 22:48:44.887
hi,
I downloaded SFCFix.exeand ran this the following auto log generated please verify and reply.
Start time: 2014-05-19 06:02:55.422
FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.2.9200.16430.
Finish time: 2014-05-19 06:42:38.554
awesome to the letter. This worked exactly as posted. "Windows Resource Protection did not find any integrity violations." Thanks so much! Hope you'll be back...
I followed your instructions with SFCfix and received the following message -
SFCFix version 2.2.4.0 by niemiro.
Start time: 2014-06-06 12:30:40.522
SFCFix version 2.2.4.0 by niemiro has completed.
Finish time: 2014-06-06 12:42:25.009
[FONT=&quot]----------------------EOF-----------------------[/FONT]
I then did a further sfc/scannow and do not seem to have a corrupt file, however, does the mention of one, without naming it, in the SFCfix matter?
Very, very grateful, thank you so much.
Betty
Betty
Welcome to Sysnative!
It does not matter because SFCFix has successfully repaired it. You're good to go :)
Richard
