[SOLVED] Window 7 Ultimate Can't Do Microsoft Updates. Help!
FRST Registry Search
  3. Select the Programs group.
  6. Copy and paste KB2789645 into the Search box and click the Search Registry button.
  3. Press the Fix button.
Reboot the machine.
Try to install KB4516065 again.
If it fails attach the file C:\Windows\Logs\CBS\cbs.txt to your next reply.
Reboot the machine.
Reboot the machine.
Peter,
KB4516065 failed again. FixLog.txt and CBS.txt (zip) attached. Sorry that the problem has become so protracted. Somehow I must have really screwed things up.
Rod
No problem.
Reboot the machine.
Remove Update Manually
    wusa /uninstall /KB:3134214
  6. Copy and paste KB3134214 into the Search box and click the Search Registry button.
Reboot the machine.
Reboot the machine.
