[SOLVED] Window 7 Ultimate Can't Do Microsoft Updates. Help!
Nice. Try to install KB4516065 only.
Remove Update Manually
    wusa /uninstall /KB:2928562
Try to install KB4516065 again.
If it fails attach a fresh copy of the cbs.txt to your next reply.
  3. Press the Fix button.
Reboot the machine.
If it fails attach the file C:\Windows\Logs\CBS\cbs.txt to your next reply.
    wusa /uninstall /KB:3102429
Attach the file C:\Windows\Logs\CBS\cbs.txt to your next reply.
Reboot the machine and run the instructions in message #89 again.
Report the result.
Peter,
Did the reboot and reran #89. Got the same error as reported in #91. In anticipation of the next step, I have attached the cbs.txt.
Regards,
Rod
FOF Communications
FRST Registry Search
  3. Select the Programs group.
  6. Copy and paste KB3102429 into the Search box and click the Search Registry button.
Reboot the machine.
Peter,
It failed. The zipped cbs.txt file is attached. I must admire your persistence! Of course, it is frustrating for me not fully understanding what is going on.
Regards,
Rod
FOF Communications
Peter,
Noticed that I failed to attach the fixlog.txt in the above message. So here it is.
Regards,
Rod
FOF Communications
There are problems with some updates but the SFC scan shows only one at a time.
    wusa /uninstall /KB:2789645
