Sysnative Windows Update
Inactive
- Oct 9, 2014
- 741
Step#1 - FRST Scan
4. Press Scan button.
6. Please attach the log back here.
7. Another log (Addition.txt - also located in the same directory as FRST64.exe) will be generated Please also attach that along with the FRST.txt to your reply.
